Question about Sylvania CL772 17" Flat Panel LCD Monitor
No audio i'm using the sylvania CL722 monitor and the audio suddenly stopped working. i checked the connections and everything seems to be plugged in the correct spot so i'm unsure why it's not working.
    Problem Solver:
  • 17 Answers
FAST YOU CHEAK AUDIO TO ANY HEAD PHONE,THER NOSOUND COMING,SO YOUR MONITOR AUDIO SECTION DAMAGE.
Posted on Jul 06, 2010
The speakers on the front of my HP w17e monitor used to work, until I connected seperate speakers so I would not blow out the monitors. Today I did not plug the seperate speakers in, and I can't get...
Check the audio jack plug from monitor to cpu if connected correctly. The audio jack plug should be connected to the sound card for audio out. You can also check if the volume in the monitor is adjusted or mute
Jun 27, 2011 | HP w17e Monitor
My speaker all of a sudden stopped working, they are built into my monitor, and worked last night. what do i do?
  1. Check the volume control in windows and make sure audio was't muted
  2. Check the audio cable and ensure it is connected to the port on the system
  3. Ensure headphones are not plugged in an aux audio port as they will mute the speakers
  4. Check the audio drivers in Device manager
  5. Try a known good set of speakers (Or CD player headphones) and ensure the audio on the system if functional
  6. If all else fails, replace the speakers ($20 or less at any major department store)
Oct 14, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
In the back of the sylvania Cl572b there is -audio- L in R asking what is ti for
These are the audio in ports if you want to use the speakers built into the monitor.The necessary cable has a single plug on one end that plugs into the audio out jack on your computer, the other end is double ended (red & white) and plugs into the back of your monitor.
Mar 16, 2009 | Sylvania CL572b (Black) 15 in.
The right Channel is not working
hello if you are sure that you check everything, speaker,cables input signal.
if this pionner suddenly stops playing in one channel the most probable is in protection not burned so it needs service at repair shop.saludos
Jan 17, 2009 | Pioneer VSX-D811S Receiver
Monitor speakers stopped working
Make sure that the audio cable from the computer is in the correct audio output (small green socket) and connected into the monitor. You can test the monitor speakers with an MP3 player or a smartphone. Also check that the volume on the monitor is up.
Jan 28, 2018 | BenQ FP71G 17" LCD Monitor
Hannspree HF259H Audio (sound) Problem
I connected an audio cable from my sound card to the audio unput on the monitor and the monitor plays everything as well as my other speakers connected to my sound card. I have a Diamond multimedia sound card (7.1 setting) By the way, the monitor speakers sound "tinny" if the volume setting on the monitor is too high.
Dec 23, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
No Audio
Check the menus to make sure the audio is not turned off. If that is OK and you have the means, try using other inputs. If it works on some inputs and not on others, that would imply a system control problem, which is unusual for that model.
Oct 15, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sylvania CL772 17" Flat Panel LCD Monitor Logo
88 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
