Question about Kaito KA1102 AM/FM/SW Radio
Auto turn off
When I turn on the radio, it automatically shuts off in less than two seconds. The instructions for the radio are very poor so I 've been trying a variety of sequences to correct this problem. Nothing seems to work. "Assuming" that the batteries were bad, I switched to the AC adaptor with the same results. Any ideas? Thanks.
Jess
  • 17,129 Answers
Trace your test to the point where the power shuts off. If possible loop up this line to give voltage to the required stage to power on. If there is an errror amp giving the instruction then this stage could be the culprit to switch off fearing a short. Check the outputs for any short or damage.Finally a good voltage check specially the reaading between switch on and off will get you to the fault but you will require a lot of patience and concentration. Use the meter and soldering iron with care and caution. Helpful? good day
Posted on Jul 06, 2010
Boss 648UA loses programmed radio stations when I start car.
Nearly every auto stereo has a two power wires. One is switched on and off with the ignition so it will shut off automatically when leaving the car and a second that has power all the time. This second power wire is used to keep time on the clock and to maintain your chosen station memory presets.
If you have wired both power wires to the switched power source, the clock and station memories will be reset each time the car is shut off. You will need to identify the wire that the radio that needs to have powered constantly and connect it to an "always on" 12 volt source (such as the (+) post of the battery).
Additionally, a car battery that is failing can cause the same problem with station memories. Look for indicators such as hard starting or interior lights that dim significantly or go out nearly completely when cranking the engine. This is a visual indicator of an excessive amount of current the battery is trying to supply - often due to a low voltage on the battery. This can be a result of a poor connection at the battery itself, a cable between the battery, starter, fuse box, etc. or a dead cell in the battery. Have the battery checked and replace if needed.
Once your radio power wiring, battery & cable connections and battery health have been verified or corrected - the problem should go away.
Jan 28, 2015 | Cars & Trucks
Poor radio reception and Setina push bar installation question
for the poor reception have you plugged in the antenna wire into the radio
May 18, 2013 | 2002 Ford Crown Victoria
Sony VAIO VCG-FE770g, turns on automatically after pressing Hybernate or turn-off
Go into power option, select hibernate, uncheck box to the left to disable hibernate, this will free up disc space and get rid of the problem. If that is not an option do a system restore before the update
Jul 23, 2012 | Computers & Internet
Clock Manuals
Hello
I've the user manual to your Sony AM/FM clock radio. There are so many model numbers to these devcies. If you give me the exact model number [not the serial number], I'll search in my system library for that manual. If has,, if you send your email address to me by Fixya comment box, I'll send a copy of it to you, if I have it.
If you need only a manual to sony AM/FM clock radio, send your email address to me now. I'll send you one[ user manual for SONY ICF-707 AM/FM clock radio. OK
Oct 31, 2011 | Sony Dual-Alarm AM/FM Clock Radio with...
When i turn my car on the my avic-f90bt pioneer goes on but after about 20 seconds shuts right off again and continues doing the same thing over and over again
Check your wiring. Sounds like you've got a bad ground, or missed a 12v source somewhere. Remember - There is a 12v constant that keeps your radio constantly tied in (so your clock stays correct, etc) and a 12v Ignition/ACC which tells your radio when you've turned the car ON or in ACC mode (which turns the radio on).
If you've mixed the two up, you'd probably get the results you're getting.
May 11, 2011 | Pioneer AVIC-F90BT GPS Receiver
The radio in my 2003 accord coupe shuts off and the backlight fades in and out. do I need a new radio or can this be repaired?
Sound a bit like a poor power connection in the back to the radio, could be the plugs has worked loose.
If you don't have or can't borrow the keys needed to extract the radio from its housing, I'd have thought more or less any auto electrician / radio fitter / garage could check it out.
Jul 01, 2010 | 2003 Honda Accord
How do I auto set up for my zoooos controller
Auto Setup automatically searches for the right code for your DVD player. For the most popular DVD player models, Auto-Setup takes a few minutes or less, however, less-common models can take much longer or this method may not work at all.
  1. Find the Auto-Setup instruction page in the on-screen Setup Guide. Your DVD player must be on the Auto-Setup instructions for this method to work properly.
  1. Engage Auto-Setup mode: Hold down the Red button until the setup light turns off. Continue holding the Red button and press the Yellow button three times, then release both buttons. If you’ve done this correctly the light will turn back on and remain on until setup mode is exited. When the setup light remains on, the controller is in setup mode.
  1. Wait for a message from your DVD player. Even though you can’t see anything happening, the controller is actually loading and testing various codes. When the right code is found, your DVD player will tell you to press the Home button. If your player doesn’t respond within about 10 Minutes or the time on the estimate chart, press the Home button to exit this method, and use the Direct Entry method instead.
  1. When the DVD player instructs you to press the Home button, be sure to do so before the onscreen timer runs out. If you miss pressing the Home button before the timer runs out, go ahead and wait until a message from the DVD tells you what to do. If you have not yet pressed the Home button, the DVD will instruct you to press the Back button to back up to the code you missed.
Jan 09, 2010 | Fun Rise Zoooos DVD System
Turns on for less than a second. then shuts off
Unplug fo a .5 hour let it reset then see what happens when I got mine to fire up the blue side to side convergane wouldnt adjust GOOD LUCK
Jun 13, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My radio turns off automatically as soon as I hit the talk button.
i hope it has only the offer to talk or radio on.
even my mobile ve same thing.it ll either in radio mode or in talk mode.
both never be activated together
Aug 26, 2008 | Uniden GMR638-2CK (22 Channels) 2-Way...
Kaito KA1102 AM/FM/SW Radio Logo
122 people viewed this question
Top Kaito Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kaito Audio Player and Recorder Expert? Answer questions, earn points and help others
