Question about Fargo Pro L ID Thermal Printer
I have the pro-l card printer that I am trying to use. When I plug the printer in it makes a clicking sound and does nothing else. Do I need some type of security card key to turn the printer on?
It's very possible that security software (smart guard) has been downloaded and installed on the printer in which case you will need a special security clearance card to gain access.
Posted on Jan 06, 2012
I have an Interlink RemotePoint VP4810 presentation remote that works great on my Vista laptop. However, when I plug it into my Windows 7 laptop, nothing. The laptop doesn't even make the sound it usually...
If you have the pro version of Windows 7 then you can run the program in compatibility mode (selecting Vista).
After you install the program, find the exe file and right click. Go to properties and click on the Compantibility Tab. You'll see options to run the software in a mode other than Windows 7.
Jan 22, 2011 | Office Equipment & Supplies
When i put the memory card in the computer nothing comes up what do i need to do?
Try going to MY COMPUTER, Then click on REMOVEABLE DISK. That should bring up the memory card. Then just clink through the folders till you find your pic, etc
Nov 02, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Sounds like it is printing but it is not
If the printer head works and you think it's printing, but nothing's showing up on the paper, you need to check the ink cartridge. Be sure that it has ink.
If the printer sounds, but it will only feed the paper and take the paper out again, then try to power cycle the printer. Disconnect the power cord from the wall socket and plug it back in after 5 minutes.
If the printer head moves just a bit, then there's no response from the printer, make sure that there are no pending documents on the queue.
Try to stop then restart the printer spooler. To stop then restart the spooler, here's how:
- Start > Run or Search > Type "services.msc" (without quotes).
- Locate the Print Spooler then click it once and make sure that it's highlighted.
- Click "Stop the service", then give 10 seconds, then click "Restart the service".
If that did not help, try to uninstall and reinstall the printer driver.
Thank you and good luck!
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
Installed logitech quickcam 9000 and now creative sound card does not work unless webcam is unplugged from usb. Sound does not work at all with webcam plugged in. Using Vista and latest drivers for webcam....
Please try plugging the webcam into other USB ports. If it still does not fix the issue, try to update the driver for the sound card as well.
If possible, conduct a Windows update as well.
Nov 26, 2009 | Logitech QuickCam Pro 9000 Web Cam
I cannot get any volume out of my laptop. I have tried Fn / F5 to mute and restore, I have checked my settings on the control panel but have still got no sound. Is there another key i am missing? Fujitsu...
have you tried looking at the advanced options in the volume panel make sure nothings muted if you had sound and you dont now i would roll back the drivers or reinstall them if you can play a song and there is no sound somethings just wrong with the settings if the sound was broken windows would tell you there was no device to play back sound with. also when your in the sound options try all avalabl playback devices
Sep 21, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Can't print from Quickbooks Pro 2008 to HP 6500 All in one
You can install Deskjet 990c drivers to print from Quick Books
We need IP address of printer for this.
Please perform following steps to get IP address of printer.
On printer press Setup >>>> select Network >>>> select View Network Settings >>>> select Print Network Configuration Page >>>> press OK >>>> this will print network configuration page >>>> note down the IP address of printer showing on this page
Now you need to install Deskjet 990c driver
On computer click Start >>>> Control Panel >>>> Printers or Printers and Faxes
Click "add a printer"
Select local printer (uncheck automatically detect my plug and play printer) click next
Select LPT-1 port and click next
select manufacturer as HP and printer as deskjet 990c and click next
make printer name as Deskjet 990c and click next
Use as default click next
Do not share click next
Select "no" to test page and click next
This will show a new icon of deskjet 990c in printers window.
Right click on Deskjet 990c >>>> click Properties >>>> click Ports
click "add a port"
select "standard tcp/ip port" and "new port"
type IP address of printer in the column of printer name
type IP_IP address of printer in column of port name
device type "generic network card"
Complete the process by clicking next/ok/finish
Try to print from quickbooks by using Deskjet 990c icon
Wish for all success..
Harpreet_351
Jul 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I HAVE NO SOUND ON MY GATEWAY GT5660E. i HAVE TRIED EVERYTHING
Do you have the speakers plugged into the correct plugs in the sound card? Make sure speakers are not plugged into the mike jack. Do you hear any static as you remove and replug the jacks? Do the speakers have a power light?
Open Control Panel ->Sounds and click on Sounds tab. Do any sounds play? Click on the Audio tab and make sure Default device is your sound card. Click on Volume tab and then Advanced. Make sure nothing is muted.
Assuming you have Windows, check the sound card in Control Panel->System, Hardware, Device Manager. Check for correct drivers. If necessary, uninstall sound card and let Windows detect it again and install drivers.
Sep 16, 2008 | Audio Players & Recorders
Fargo Pro-L Not Printing Edge-To-Edge
These direct-to-card printers do not print right to the edge because of the way the print head comes down on the card. There will always be a white boarder on the card especially if your graphics are dense. The only solution to this issue is to re-design your artwork so that the image fades at the edges of the card so the white boarder is not obvious, or purchase a re-transfer printer which will give you true over the edge printing.
Dec 14, 2007 | Fargo Pro L ID Thermal Printer
SmartGuard troubles
I am having the same exact problem with the Pro L. Did either one of you figure it out? I just spent $100 on the SmartGuard and now I cannot get it to work
Sep 29, 2007 | Fargo Pro LX ID Thermal Card Printer
Fargo Pro L ID Thermal Printer Logo
41 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
