Question about D-Link DIR-625 (790069292637) Wireless Router
Want to hook cpu in and run ethernet to modem port. Will not connect. It seams ethernet port is bad, can only use 1 of 4 single port, which wont allow multi system connection. anyway to trouble shoot/reboot ethernet port? Or just buy a new router?
  • 29 Answers
When you plug it into the computer do you get a IP? click start run cmd in the blackbox type IP config if you get numbers pay attention to the gateway should be something like 192.168.1.1
Open a webpage and type the gateway IP a box will pop up asking for a user name and password default is admin password is password From the following pages you would be able to see the internet status if you have a IP address then it should be good. Now verify all the other ports. Assuming you are still in warranty status If any of the ports does not work linksys will replace the router for you. Hope this helps
Posted on Jul 05, 2010
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Modem light is blank on motorola wr850g, how do i fix?
If the modem light is not turning ON,
1) check if the modem is ON
2) check if the ethernet connection is properly made
3) check if the port on the modem is working, confirm it by connecting it straight to the computer.
4) check if the ethernet cable is working fine.
5) Then try power cycling the router. Unplug the power cable and connect in back after 20-30 secs.
6) Then try pressing and holding the reset for 20 secs.
7) Finally connect a single ethernet cable from any LAN port to WAN port and check if the modem light is ON.
Ultimately, if even after this step, if the light doesn't turn up, either the modem LED would have gone bad or the WAN part of the router would have gone bad.
For further clarifications, revert!
Thanks for asking,
Regards,
Arvind S Iyer
Sep 29, 2010 | Arris WR850G Router (DHWR850G)
How to connect 2nd computer to internet from bsnl type2 modem modelzxdsl 531b through ethernet cable
Its simple
1. connect a lan cable from ur modem to ethernet switch(For ex: 4-port)
2. Take 2 cables from ur switch ports and connect it to ur Pc's
3. Configure DHCP on your modems. So that ur pc's obtain ip address automatically from ur modem.
This is how u connect multiple computers to internet by a single internet connection
Jul 06, 2010 | Computers & Internet
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dont no how to hook up wires to modem
Its very simple...
Take the ethernet cable from your modem, and hook it to the "internet" connection on your router.
Then take another ethernet cable and run it from your computer to any of the other ports (1-4).
Nov 08, 2009 | Linksys Wireless-G WRT54G Router
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Trouble with paradyne or linksys
Just saw your post, so please accept my apologies for being almost a month late in responding, as I only joined this service on March 26th.
1. When a modem has both usb and ethernet, only ONE of the two should be used as most isp modems will allow one or the other.
2. Your Vonage should be discreet and not intermingled with the rest of your system. It would be better to connect the Vonage to a router, and not the router to the Vonage. iow, do not connect the Vonage modem between the isp's modem and your router.
3. denigration of service or slowdown is typical with VOIP if more than 2 systems whether telephone or other systems are connected, due to the ringer voltage splitting that occurs when you put more units on the Vonage, or any other Voip modem. One ISP solves this by providing separate outputs for Voip and Ethernet.
Observation of these rules should speed up your system.
Mar 01, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Ethernet port
two ports will be available on the CPU, normally 1 port for the phone cable and the other to modem, please connect to one of these ports and see.
Feb 07, 2008 | Computers & Internet
Ethernet card
You either have a bad ethernet port on your modem or pc. If your modem has a USB port, hook that up and run the modem disc to load the driver for USB. You may still be able to get online that way.
Jan 27, 2008 | AMD Compaq Presario SR1030NX Athlon...
D-Link DIR-625 (790069292637) Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
