Question about RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw
Hi I have 7 Kawasaki 21.6 cordless drills Model 691220 and they all have same problem the power swich is burned out I took one apart and found that the plastic is melted completely trough the one spot where the contact makes when the trigger is depressed. Do you know if there is a recall and where I can get these switches Thanks Mike
I need a trigger switch for my Kawasaki cordless drill 691220
there a possible answer here.
http://www.fixya.com/support/t5303722-8_kawasaki_21_6v
Jul 03, 2017 | kawasaki Drills
When I pull the trigger on my cordless drill smoke comes out of the vents and you can smell burning odor
The motor has jammed and burned out. It is probably not worth trying to repair.
If it is still within the warranty period take it back for replacement under guarantee
Feb 10, 2011 | kawasaki 840079 Green 19.2 Volt Cordless...
Where can I get a replacement trigger switch? The one in the drill is in a locked position and cannot be moved. I too the drill apart and got it to move now there is no responce This is a 19.2 volt...
Call the service # and they will send you a new drill, mine had a burn mark right through the switch and with the model # they replaced it mine was a21.6 they are having troubles with the triggers i pulled mine a part and when i put a battery in it it would run continuous , the number should be on the drill1-800 590-3723
Nov 20, 2010 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Same problem, switch has melted
check with kawasaki to find the problem. well get back
Sep 08, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Bad/cheap drill
I agree. Did you have a question?
Jul 23, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Kawasaki 19.2 cordless drill
I will go one further, they had a recall of their batteries which could have led to your problem back in 2007 and the chargers on some of them also. I would again call the number and give them the date codes from both and then try again at getting it replaced. Their are a lot of posts online for this to be a simple occurence, The battery could have shorted internally causing the switch to melt and there would be a potential for user injury also. Let me know if you find anything out and if you have there web address I would be interested.
Jun 01, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Hi Tim, Sounds like you got it figured out! The only question I see is if there is a quick fix, and it looks like you answered your own question. You can certainly pursue requesting that it be fixed as a manufacturing defect/ faulty part, or even a safety hazard as that is your right. While I can not suggest you take that route, the old metaphor of the sparking trigger that melted in my hand always seemed to get a lot of attention. Good Luck to you, hope this Fixsya!
Mar 13, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Kawasaki 840079 Green 19.2 Volt Cordless Drill Just stop working
It is possible that you overloaded it in high range and maybe stalled it out. Usually when the motor burns it is from overloading/overheating. If this is a newer tool I would try and take it back for warranty repair and not say anything about the smell. Its worth a try, some of the motors for the cordless tools are around 50-60 dollars
Mar 11, 2009 | kawasaki 840079 Green 19.2 Volt Cordless...
Re: Burned trigger switch: call the number on the drill (800.590.3723) and tell them what happened. They will offer to send you a new switch or have you send the drill in for replacement of the switch--although the person I talked with said they would probably just replace the whole drill.
Dec 13, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw Logo
356 people viewed this question
Top RTO Drills Experts
Are you a RTO Drill Expert? Answer questions, earn points and help others
