Question about Acer Aspire 7720 Notebook
I have a new HDD for my Acer Aspire 7720 but i cant find how i replays the old HDD 80 GB for my new 1 160 GB can someone help me???
    Guru:
  • 417 Answers
Turn it over & it's under the smallest panel you can see i think,It's under one of them.It should just slide across & pull out it might be screwed down.
Once you've got it out you'll need to remove the caddy ie the metal case around it,should be just 4 screws 2 on both sides.
put the new in & screw it all back together.
You do realise that you'll have to reinstall windows on to the new drive & that you'll need to save all your data off the old one on to CD,FLASH DRIVE or EXTERNAL HHD in order to use it.
If you get stuk TEL:01228 523603 E-MAIL:djtatty@hotmail.com
Posted on Jul 05, 2010
How do i clear hdd password when i dont know password ?
You could try asking Acer, if it is the original hdd or purchase a new hdd.
Aug 28, 2014 | Acer Aspire 7720 Notebook PC
My 80 GB External HDD ( Hitachi Travelstar not working Which is under waranttee
Hitachi maintains a page to answer questions about obtaining warranty service at the link below:
http://www.hitachigst.com/hdd/support/warr_faq.htm
You must obtain and "RMA" (return merchandise authorization) prior to sending any drive to Hitachi. This entire procedure is outlined at the link above.
Please rate this replay if you found it helpful. Good luck!
Jul 06, 2010 | Hitachi TravelStar 80GN 80 GB Hard Drive
Acer Aspire 5330 Hdd error code 14402 How can
Please try use following codes..
01560000
PLFU2RR
U0N5U05
RSIYMDE
W7XXAA1
VJHICXN
DUOXXYM
D8WWW15
May 18, 2010 | Acer Aspire 7720-6569 Notebook
My Acer Aspire 7720 cannot connect to the internet
go to network and sharing center. it should be where you click on the internet icon down at the bottom in taskbar right side. when it opens try setting up a new network. if that don't do it check to make sure your wi fi is on or needs resetting. also on that page in the network center is a pretty good troubleshooter. good luck
Apr 05, 2010 | Acer Aspire 7720 Notebook PC
My acer aspire 7720 switches off everytime i load my webcam or play games on facebook. what do i do?
Sounds like overheating to me, due to the increased heat from the video card. Turn the computer off, remove the bottom cover, blow air from a compressed air can, check the fan(s) can move easily, re-install the cover and restart.
BEFORE you play any games, I suggest you install CPUID Hardware Monitor (it's free).
http://www.cpuid.com/hwmonitor.php
Install and run. Check the temperatures of your CPU and video GPU. They should never be higher than 80 C (80 C is the very worst case scenario, it should normaly be lower than that, unless there is a problem)
Mar 19, 2010 | Acer Aspire 7720 Notebook
Acer 7720 will turn on and work for about 5 mins and shut down
In most cases I have found that this problem stems from a bad charger not delivering the proper amount of voltage. Therefore the battery doesn't ever really get a full charge even though the power indicator may say it does. I would get a multi-meter and check the voltage at the charger tip and see if the power is fluctuating. Be careful regardless, a bad power unit may spike and terminate your motherboard.
Sep 12, 2009 | Acer Aspire 7720 Notebook
Acer aspire 3500 note book old hdd broke new hdd in no disks
Yes go to this site:
http://us.acer.com/acer-v2/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Select Notebook, Aspire, and then the model number. All the software is at the bottom.
Jul 23, 2009 | Acer Aspire 3100-1405 Notebook
I formated completelly hdd (acer 7720g) i want to to recreate pqservise in order to have d2d recovery(recovery management).i have the dvd recovery of factory settings but the dvds didnt manage to create...
You cant access the recovery partition because you probably has deleted them accidentally. Try to delete all the partitions and use the recovery CDs that come with your computer, they could help.
Good luck.
May 23, 2009 | Acer Aspire 7720-6155 Notebook PC
2nd hdd on acer 7720g
I support the suggestion posted by Joed911. This is the best way to connect the 2nd HDD.
Apr 12, 2009 | Acer Aspire 7720 Notebook
Ram Install access upgrade
Below the Notebook There will be access flap to put the ram. May even you need to Keyboard for few models.
Mar 11, 2008 | Acer Aspire 7720 Notebook
Acer Aspire 7720 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
