Question about Magic Chef CGR1430 Gas Kitchen Range
The oven won't heat up.
We have a Magic Chef oven, model CGR1430BDT. For awhile it took a long time to heat up and sometimes if we turned it off and back on again it would heat up normally but now it won't heat up at all. The range works fine but there is no heat in the oven.
SOURCE: Magic Chef oven won't light
Replaced the ignitor.
Posted on Oct 09, 2009
  • 833 Answers
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
Posted on Dec 03, 2007
fridgetech
  • 473 Answers
SOURCE: magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Posted on Oct 18, 2007
SOURCE: oven does not heat up
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
Posted on Nov 18, 2008
frcs68
  • 1605 Answers
SOURCE: How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
Posted on Apr 07, 2009
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
My magic chef rv range will not light the burners with the ignitor. I replaced the ignitor at the control due to the wire prong being broken off. It worked prior to the wire prong breaking off. What do...
hope this helps a little...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/15-104--/Magic-Chef-Stove-burner-won-t-light
Jan 14, 2018 | Magic Chef Ovens
Magic Chef CGR3742 Hi, I't has been pre heating, but took a very long time. Now it sometimes will heat up a little, but will not hold that temp. for long. I removed the bottom pan to see the burner and...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
Nov 14, 2017 | Magic Chef CMV1000B Microwave Oven
My Majic Chef Oven model CGR3760 is taking a long time to heat up. It took 1 hour to reach 450 degrees! Not sure if this might be a thermostat issue or burner. Penny
Turns out it was the ignitor going bad but not totally gone. We are waiting on a part to come it to replace it. Thanks. By the way, this is a neat service, keep up the good work!
Jan 31, 2010 | Magic Chef CGR3725 Gas Kitchen Range
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Nov 24, 2008 | Maytag MMC5000 Microwave Oven
Surface Heat and other lights will not light up. Will not get hot but is trying - gets slightly warm. This includes burners and oven. The cooking light will come on in the oven but nothing more. The...
you have a power promblem start where the cord connects to the range and go back from there to the fuses before you pull it out turn off the breakers loose connections will cause the cord to short out sometimes
May 24, 2008 | Magic Chef Kitchen Ranges
Magic Chef CGR1430 Gas Kitchen Range Logo
285 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
