Question about Maytag MDG4000 Dryer
No heat in dryer
No flame thermacouple at
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryerno heat in dryer - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is ..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
3rd thermacoupler in 1.5 months. I can get the pilot to light and heat a tank, but it will not recycle. Once the tank is hot the pilot goes out. Obviously not the thermacoupler unles strange odds that 2...
Your DESA/Vanguard Vent-free, Blue Flame Heater has a pilot assembly that is equipped with and Oxygen Depletion Sensor (ODS) . When this becomes clogged with dust, lint, spider web, etc, the pilot may light and burn for a few minutes, but will soon shut down. As the ODS senses that there is not enough oxygen for safe combustion. This mimics a faulty thermocouple. A good indication that the pilot is dirty, is when the pilot flame curls upward and looses contact with the thermocouple. Cleaning the pilot and it's ODS with canned air and a straw nozzle (like you clean your compute with) should solve the problem.
To further help you, I have included a link to the Owner's Manual for your Model, as well as a link to how to clean the pilot & ODS
http://www.desatech.com/manuals/Vent-Free%20Heaters/107884-01.pdf
Cleaning the burner & pilot demo: http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Desa International GWN30T 30,000BTU NatGas...
Pilot and Burner shut off at same time at various run times.
sounds like your pilot saftey is working.the pilot flame heats a device called a thermacoupler which gives a signal to the gas valve letting it know its ok to open main valve. you may need a new thermacouple , might have a dirty pilot orfice or a problem with gas pressure or worse case a cracked heat exchanger in any case in less you have some type of training you should call a pro
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Pilot going out
I'm having same problem with two, so cleaning them again, this time with duster. Will let you know if it works.
Dec 17, 2008 | Vanguard International Blue Flame - Large...
Patio heater tip switch doesn't let gas through
it sounds like what you are describing is a bad pilot saftey device there is a device called a thermacouple when heated it creates a small electric current which lets main valve know its ok to open we have a pilot flame.the thermacouple normally screws onto gas valve it is 2 spade connectors it is a powerpyle system
Nov 23, 2008 | Coleman 5040-751 BackHome Open Flame Patio...
Amana Dryer LG8409W2 - The dryer heats for a few seconds then runs cold. The dryer has been cleaned as well as the vent and still no heat.
karenl46 -- Flame sensor has to "see" proper flame in order for gas burner to stay on. Safety solenoid engages (shuts off gas) when flame light not detected. Check window on sensor (1:30 CW position) on burner tube. If you still have problem after cleaning it, then refer to URL below. -- SWT
http://forum.doityourself.com/kitchen-laundry-home-gas-appliances/350993-another-gas-dryer-no-heat-failure-rates.html
Aug 18, 2008 | Amana Dryers
Dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Jul 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
97 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
