Question about Thetford Norcold RV Cooler/Freezer
I have a Norcold gas/electric Fridge in my rv. The model number is 8662. I had th rv parked in my driveway and didn't realize the fridge was on. My driveway is no where near level and the fridge stopped working. The freezer still works but not the fridge. Could this be the amonnia has crystlized and if so how can I fix it?
    New Friend:
    Problem Solver:
  • 9 Answers
You shouldn't have to lay it on its side, or "burping it", I had the same issue and realized that it is a gravity operated cooling system. I had no idea what any of this meant and tried to call Norcold to get some help...they were useless! I called the Norcold Guy (http://thenorcoldguy.com/norcold-technical-blog/) and they had a few helpful people that broke it down for me. Would probably call them again if something else breaks. Norcold RV Refrigerators and Parts for Sale
Posted on Oct 14, 2016
I ran into the same issue today on my 8663 (same one but 3-way I believe). The Norcold users manual says to pull the fridge and lay it on it's left side for at least an hour to let the water and Ammonia remix. I gave it a shot and cleaned the half-clogged cooling fins while it was out. I'll pop it in tomorrow. If letting it sit for 24 hrs didn't fix it as was previously suggested you might try this. Took about 30 minutes to remove, simple to disconnect, but takes 2 people due to weight and size.
Posted on Jul 19, 2010
  • valiunas Jul 19, 2010
    I ran into the same issue today on my 8663 (3-way version of 8662 I believe). The Norcold users manual says to pull the fridge and lay it on it's left side for at least an hour to let the water and Ammonia remix. I gave it a shot and cleaned the half-clogged cooling fins while it was out. I'll pop it in tomorrow. If letting it sit for 24 hrs didn't fix it as was previously suggested you might try this as second step. Took about 30 minutes to remove, very simple to disconnect, but takes 2 people due to weight and size.
  • Thetford Master
  • 6,674 Answers
Shut it down, level it up and wait 24 hrs before turning it back on.
Posted on Jul 09, 2010
Norcold 682 rv fridge on gas lights for 5 seconds then shuts off panel has red x
check for weak pilot check tube to ignitor if ok possible flame sensor dirty or bad
Sep 05, 2014 | Thetford Norcold RV Cooler/Freezer
Refridge not working
Even if your plugged in, you'll have to confirm you have 12Volts DC going to back of fridge at connections, behind vent cover. Is the upper board on front of fridge lighting up when you turn it on? Could you also give me model number off fridge to help guide you better ? Model # should be on inside of fridge.
Dec 08, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
Sep 27, 2009 | Thetford Norcold RV Cooler/Freezer
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
Rv fridge not working on electric
the element can be broken or the thermostat
Aug 11, 2009 | Refrigerators
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold RV Cooler/Freezer Logo
1,165 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
