Question about Toshiba Computers & Internet
Ok the problem is when I leave my laptop alone without touching it the screen goes black and I need to press the power button so it goes to the login screen. Then I log in and my programs are still there. I go to my settings so the computer doesn't lock for certain amount of time, but it does nothing! Please help
melnavz
  • 1226 Answers
SOURCE: Dell Precision 670 Workstation possible VRM 0 issue
I can figure out what happen to your PC. However since that your pc keep slow ..If you can do open your pc and try to refix all the connection. the memory, hard drive, VGA card and other and test.. if this not solve then try to restore your original by reinstalling your windows operating system.
may this help,
melnavz
Posted on Jun 25, 2008
  • 61 Answers
SOURCE: HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Posted on Feb 10, 2009
craigjamesbt
  • 65 Answers
SOURCE: When i try to log into my macbook...
try checking your disk / disk permissions (note:to verify disk you must start from the os x cd at the top of the screen click utilities -> disk utility->repair disk)in the finder window after login you can press command N (apple key and N key at the same time) open the applications folder and find the utilities folder open utilities folder and double click 'Disk Utility' select the disk you wish to repair from the list on the left and click repair disk permissions (note you should back up important files before performing any disk repair utilities) also if you cannot log into the finder you can simply insert the os x disk and hold the C key down after the first boot chime this will start from the cd drive (which may take a little while)
Posted on Apr 23, 2009
smartr10U
  • 1305 Answers
SOURCE: my Mac Book will not work i plug in the power cord
Have your Mac OS disc handy, start your computer, as it starts, press and hold the power button, this will cause the mac to shut off. Then push the button again, while it is starting push your os disc in the drive. The goal is to get the computer to load the OS disc so you can access the Disk Utility program from the file menu.
If you're having trouble getting past the fan still, restart while holding the commnad, option, p and r keys together. Continue to hold these down until you hear the start up chime. keep holding and let it do this twice. This is "zapping" thie PRAM ... Then start it again... These should help...
k
Posted on Sep 09, 2009
cvyoung
SOURCE: Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Posted on Feb 02, 2010
How do i reset my ipod touch
If you are talking about resetting after your iPod Touch has hung, you need to press and hold the top and home buttons until the screen goes black. If the iPod Touch displays the "Slide to power off" message, ignore it and continue to hold down both buttons until the screen goes black.
Turn on the iPod Touch by pressing the top and home buttons together again just briefly. It will take a while for the iPod Touch to start up from this type of reset.
If you are looking to restore the iPod Touch to factory defaults, you need to start iTunes on your computer and plug your iPod Touch into your computer with the USB cable that came with it. Click on the iPod Touch from the list on the left side and press the "Restore" button.
Jan 29, 2012 | Apple iPod touch
The compuyter made a very funny running sound and then the screen with black. I can not start up the laptop, but 2 blue power buttons are on.
You got 2 options:
1-Start the pc and when you see Windows Welcome screen / Login screen, press ctrl>+alt>+del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows. Now you can reset your account password from "Control Panel -> User Accounts". Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2-Some computer systems have a setting in the BIOS Setup to disable the password. The BIOS Setup is accessed with the F1, F2 or DEL key during boot up. If you have forgotten your password, most systems have a jumper on the motherboard that can be pulled off to clear the password. If there is no jumper available, you can also remove the battery for 5 minutes to clear CMOS.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Dell Vostro 1500 Notebook
I have Dell Optiplex 740. When I press the power button the PC goes thru POST OK but, once it looks for the OS the screen goes black and never displays anything. If I power reset again, it does the same...
Boot with your recovery CD and select REPAIR and boot into the recovery console
from the command line type
fixboot c:
If that doesn't fix your problem reboot into the recovery console and at the command line try
fixmbr
Jan 23, 2011 | Dell OptiPlex 740 PC Desktop
IBM R40 laptop will not start.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 22, 2010 | IBM ThinkPad R40 2722 Notebook
HTC Touch Diamond - Powers up and down while plugged in
from a power off device.
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
good luck!
Aug 29, 2009 | HTC Touch Diamond Smartphone
Login to router
ok
try
username as "admin" and password as "admin" or blank or "password"
Jun 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Laptop screen.
Ok, Start the laptop in safe mode.
Press F8 (do it a few times) just after the initial screens have faded when you turn the laptop on.
You will get a Windows Startup screen.
Select Safe Mode and press Enter twice.
After you get into Windows, goto..
Start - - Run
Type msconfig and click the OK button
In the new window that pops up select the Startup tab.
Click the word Manufacturer and it will sort the list into order.
Scroll down the list and remove the ticks from anything where Microsoft is NOT the manufacturer. Also make sure to leave your Anti Virus software ticked. It may list itself as anything, but reading the text will let you know what is what. If unsure, then just leave the Microsoft boxes checked and the rest unchecked.
Click Apply
Then OK
OK any other boxes that pop up, and restart normally.
Post back and let me know if you can now get in normally and we can proceed from there.
May 16, 2008 | Acer Aspire 5100 Notebook
Boot failure
does it beep at all?
take it into a dark room, can you see anything on the screen, even if it's very faint?
take battery off and plug in same thing?
Jan 04, 2008 | Toshiba Satellite A105-S4004 Notebook
Laptop monitor goes black
Welcome to Vista. Windows Vista is automatically set up to power down after you have left it alone for too long. If you press the power button everything should be fine. Otherwise tell me what happens.
Dec 09, 2007 | Acer Aspire 5100-5022 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
