Question about HP 920 Plain Paper Fax
Fax sends certain pages in duplicate
My fax machine sends certain pages in duplicate. For example, if the fax is 7 pages long, it sends pages 2,3,4 twice and the rest only once????? This happens to only one vendor, not everyone I send a fax to. Any solutions???
  • 903 Answers
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Posted on Jul 06, 2010
Tip
SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)Posted by...
<a href="http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/">SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)</a> <span>Posted by <a href="http://www.smtp2go.com/blog/author/admin/">mi6</a> on </span>August 19, 2009 - 4:06 am <span>Filed under <a href="http://www.smtp2go.com/blog/category/uncategorized/">Uncategorized</a></span> Some Sharp fax machines require a certain type of SMTP server in order to be able to send emails. SMTP2Go provides an SMTP server that authenticates senders based on their 'from' email address, meaning that it works with fax machines that are unable to send an SMTP username or password.<br /> Two examples of SMTP setup procedures for popular Sharp fax machines are below:<br /> Sharp UX-B800SE and UX-D1200SE Broadband Fax SMTP setup In the 'Network Settings' area, enter smtp2go.com as the SMTP server, and <b>UNCHECK</b> the box 'POP before SMTP'. Try entering either port 2525, 25, or 587 as the outgoing SMTP port. Then, make sure you are sending 'from' an email address that is registered with SMTP2Go.<br /> See a sample screenshot from the UX-B800SE fax below (click on it to enlarge):<br /> <br /> <p><a href="http://www.smtp2go.com/blog/wp-content/uploads/2009/08/sharp_fax_ux-b800se_smtp_setup.gif"><img src="sharp_fax_ux-b800se_smtp_setup_small.jpg" /></a><br /> Please note that Gmail's SMTP server doesn't work, as it not only requires a username/password, but it also requires that SSL/TLS is used.<br /> Please note: some fax machines may still have a problem sending - if this is the case, use the IP address of 207.58.142.213 instead of smtp2go.com as the SMTP server.<br /> SHARETHIS.addEntry({ title: "SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)", url: "http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/" }); <span><a><span>ShareThis</span></a></span><br />
on Feb 15, 2011 | Office Equipment & Supplies
Keep receiving duplicate faxes
Some Brother fax machines are programmed incorrectly so they do not acknowledge receiving the last page of a document. The sender doesn't know you got it, and will resend.
It's harsh advice, but the only solution is to buy a different brand.
May 07, 2010 | Brother IntelliFAX 4100 Laser Fax
It takes 20 minutes to send a single page fax.
Did you switch to a DSL or digital phone line?
Sep 30, 2009 | Office Equipment & Supplies
When sending a fax on the faxphone L80 it pulls in duplicate page
There is a little rubber pad where original feed in. Look at it on edge and you'll see it has concave wear. Carefully remove black plastic hold down and flip rubber pad over. You'll have to make a new hole so it will lay flat.
Apr 06, 2009 | Canon FAXPHONE L80 Laser
How to send the same fax to several fax numbers?
it's called "broadcasting". open your owners manual, turn to page 7-3, and begin following the directions. quite simple, but too long to explain here.
hth,
razors
Jan 09, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
down on the scanner glass.
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
document.
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
Note
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
HP 920 Plain Paper Fax Logo
161 people viewed this question
Seeker5211
Seeker5211
