Hello, I own a 2003 phillips 46" rear projection HDTV model no. 46PP9302 & serial no.78201545. I went to change the channel and the picture just went out but there is still audio. Could it be the picture tube or bulbs that I see in the back. Are they very expensive? Do all three need to be replaced. If not how can I tell which one it is? Is this job very complicated to do yourself?
  • 8,617 Answers
Try resoldering the vertical output IC thats most likely the problem if not the vertical output IC may need replacing. If you can solder you may be able to do this yourself as its not a hard repair the replace the output IC
Posted on Apr 18, 2008
Philips 64p9161006 I changed stk-150 still same problem what else can it be screen warped
Did you replace the (12) 6.8 ohm resistors when you replaced the ICs? There will always be at least 1 of the resistors that will be blown when a phillips ICs fail.
Oct 20, 2010 | Philips 46PP9302 46" Rear Projection...
Phillips Rear Projection HDTV just shuts off.
I reacon it might be nearly as cheap to replace the tv because there are only 2 thing which can cause this problem dry joints on the solder ( Quite rare on this type of telly) or the line output transformer and that will cost you nearly a hundred pounds
Nov 27, 2009 | Philips 46PP9302 46" Rear Projection...
Colors are off
Thats a convergence Issue, Heres a link to a repair kit which contains instructions on how to install the repair kit
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jun 22, 2009 | Philips 46PP9302 46" Rear Projection...
Picture is fuzzy and color seems faded
Sounds like your coolant in the tubes need to be repalced. This is a common problem as the set gets older. Check with www.TvRepairKits.com for the supplies and instruction guide.
Dec 09, 2008 | Philips 46PP9302 46" Rear Projection...
Phillips hd projection tv/ model 60pp9363h/17
thats a common problem with all projection tvs. You will need to replace both convergence Ics and 4 resistors. You will need two STK392-120 Convergence ICs and four 6.8 ohm 1watt resistors. You can get replacement parts at the following link and they provide free instalation instructions so you can do the repair yourself. heres the link.
Sep 01, 2008 | Philips 46PP9302 46" Rear Projection...
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
