Question about Briggs & Stratton Briggs Stratton Pro Series 8 Gallon Wheelbarrow Air Compressor
Backfire out exhaust
Intek 24 hp v twin engine
  • 10,319 Answers
You will need to adjust the intake and exhaust valves to eliminate the backfiring. This is common to all small engines. I suggest every two years under normal use to adjust them. .008 thousands is standard on most Briggs engines although I would Google your model number on the web to find out for sure. The valves have a lock not that simply loosen so the nut below that can be turned for the clearance to gap.
The valve cover has screws that remove to gain access to these valves. Silicone sealer can be use to make a good deal for a gasket as well
Posted on Jul 05, 2010
Briggs 5 hp backfires through muffler
Exhaust valve is not closing completely or the valve seat is cracked.
Sep 24, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Why does my Briggs & stratton 24 hp intek v-twin **** and pop at full throttle causing black smoke out of the exhaust?
Does it do this when you start it or turn it off? If yes to either one you must install a gas chock in the fuel line. It's a valve. You turn the valve off and let the engine run out of gas. When starting you turn it on obviously. By draining the carburetor of gas it won't overload anymore and backfire when turned on/of f.
Sep 17, 2014 | Cub Cadet Garden
How to replace ohv cam on 17.5 briggs model 31c707-1346-b2
I SET THE INTAKE VALVE AT .005 AND THE EXHAUST VALVE AT .003 AND THE EXHAUST VALVE MOVES ONLY HALF THE DISTANCE OF THE INTAKE. IT IDLES OK BUT GIVE IT SOME GAS AND IT BACKFIRES THROUGH THE CARBURATER AND SHUTS DOWN.
Oct 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
B&S V-Twin 24 hp has done 150 hrs and has now started to backfire a lot. Engine starts well
Take off the valve covers and check the valve lash. @ tdc on compression stroke then same on exhaust stroke the clearance between the rocker and valve should only be .001 to.003 in.Carefully adjust to this tolerance,may cure your problem. seems this is a common problem.
Nov 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs  Stratton Pro Series 8 Gallon Wheelbarrow Air Compressor Logo
103 people viewed this question
Top Briggs & Stratton Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Air Tool and Compressor Expert? Answer questions, earn points and help others
