Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
My ec 12 compressor will run and shut off around 125 psi and then it bleeds off untill it turns on around 80 psi Ive replace the pressure switch and its still doing this Why?
  • 3 Answers
It souds like a sticky "non return valve". See the fix below.
The non return valve is the chrome part with a hex cap adjacent to the upper tank. Remove the cap and make sure the piston moves freely. Slight resistance is ok, but if it sticks your compressor willl continually blow off air.
The check valve or "non return valve", as listed in the Hitachi parts manual is definitely the culprit here, but there is an alternative solution to replacing the entire valve that was actually suggested to me by a Hitachi Tech when I stopped by my local service center to pick up a new non return valve. Obviously, the rubber piston swells and sticks to the point that the spring under the piston can't over come the friction. I removed the piston and carefully reduced its diameter, by hand, with varying grades of wet or dry paper and it now operates perfectly. If one is uncomfortable with such a repair, at least keep it in mind for a quick jobsite fix. I have now been running my repaired compressor for several months without issue.
Posted on Aug 23, 2010
    Problem Solver:
  • 18 Answers
You probably need to spray some penetrant on the high pressure relief valve and turn the ring attached to to rotate the stem of the valve. Also called the pop off valve.
Posted on Jul 10, 2010
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Poor air compression
I would guess from the info supplied that the pressure switch is shutting it down at 125. Most piston type compressor only pump a max. of 175 unless it is a special high pressure unit. Also it may be shutting down on high amps, high temp etc.However with all that said Piston units are positive displacement, meanning that it should pump until something gives. Start your unit, close the discharge air valve and see what it pumps up to. May have to adjust pressure switch to get over 125. If unit runs and runs and just will not go over 125, you probably have a valve going bad. Do you have a safety lifting. if so another indication of a bad valve.
Nov 27, 2011 | Ingersoll Air Tools & Compressors
Comperrsor pumps uoto preassure, but when the preasure drops it tries to start . The motor come on but will not turn compressor until preasure drops to about 20 lb. Then it will start and build up to...
Run the compressor until there is about 75 psi in the tank and turn it off at the pressure switch. Remove the black bleeder line from the pressure switch:
1. If absolutely no air comes out of the line you may have a bad start capacitor on the motor. Have it tested at an electrical or refrigeration shop or just replace it to see if it takes care of your problem.
2. If you get a short blast (five or so seconds) of air then nothing your pressure switch isn't letting the head pressure bleed off after the motor shuts off. This pressure has to be relieved or the motor has to fight the tank pressure when it tries to restart. Reconnect the bleed off line and turn the motor back on. If it starts normally, replace the pressure switch. If it struggles or won't start it is more indicative of a bad start capacitor.
3. If you get constant air flow from the bleed line the problem is with your tank check valve. This causes the same problem as above. Replace the check valve.
May 04, 2011 | Ingersoll Rand 30 Gallon Garage Mate...
I have an IR Air Compressor #SS3 E. It want stop running/building up pressure. I am sure its the pressure relief valve, but there are 2. One at the presure regulator and the other at the pump and motor.How...
if it is lifting both valves I would say that the pressure switch (regulator as you call it) is defective, if you try to shut it off using the manual switch and it keeps running, I would say that the switch is welded shut. if it does not shut off by 125 psi then it is faulty. The pressure switch is what controls the motor in response to pressure in the tank.
Jan 31, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Saylor-beall air compressor D-B-200-HA builds up to about 120 psi and shuts down but it bleeds down to 80 psi and restarts do I need a new pressure switch or can it be adjusted? it has adjusting screw on...
I am almost sure what you have is only a single pump and should only rut out 125 psi tops. you should not exceed this with a pump of that type. If it is a 2 stage pump (one large and one small cylinder) they can commonly go to 175 psi. But as always check to see what the maximum pressure your tank was certified and do not ever exceed it.
Dec 08, 2009 | Air Tools & Compressors
Hitachi EC 12 Air Compressor does not keep pressure
to repair this problem (a) the pressure switch is not working,(b) check valve or non return valve sticking(stripe down repair and refit)
Sep 28, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
Jun 14, 2009 | Hitachi Air Tools & Compressors
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Twin tank air compressor does not pressurize past 65 to 80 psi.
machine inlet valve not sealing in cylinder head valves need to be removed for assesment
Dec 03, 2008 | Northern Industrial 2 Hp Twin Tank...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
614 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
