Question about Refrigerators
Side by side fridge. Makes ice but will not dispense water
  • Anonymous Apr 03, 2009
    HOW DO YOU FIX FROZEN WATER LINE INSIDE FREEZER DOOR OF GE SIDE BY SIDE.COULD YOU LEAVE DOOR OPEN OR USED HAIR DRYER AND BLOW BY WATER OUTLET .
  • 145 Answers
Could have a frozen water line in the freezer door. You should have a connector at the bottom of the door. If you pull it loose you can hit the lever to see if water gets to there. If so the problem is in the door. If not you will have to work back to the valve at the back of the unit to see where it stops getting to.
Posted on Apr 18, 2008
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire GLRSF266J side by side makes ice, but dispenser won't work, what can I do?
The part that holds the switch in the dispenser door may have allowed the paddle to no longer contact the switch correctly. Look for a discolored wire connector under the hinge cover on the freezer door. If it looks all in order the water solenoid located where the water line attaches to the fridge may be bad.
Jun 28, 2015 | Frigidaire Refrigerators
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
My GE side by side fridge doesn't dispense water.
When you press the handle, do you hear/feel a click?
Is this just starting to happen after a power outage?
Is the ice machine making ice? Dispensing?
Do you have/know how to use a multimeter to check voltages at the water valve solenoid?
Thanks!
Feb 21, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Figidaire model frs26r4cbb side by side dispenses water and makes ice if i poor water into the tray but will not fill on its own
There is a valve that allows water to go into the trays and generally it is behind your fridge where the water line connects into the fridge. This valve is generally the problem but not always. Here is a link to a site that gives you drawing on your fridge and also the parts to repair it if need be. I hope this helps.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Refrigerators
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispenser
wow that's agood one!!!! theres a short for sure, just a matter of where. somehow your energizing both sides of water valve at once, sounds as if it would be behind the dispensor, at the switches. would remove the dispensor cover and have a look for a bad switch or exposed wire
Mar 08, 2008 | Refrigerators
Refrigerators Logo
365 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
