Question about Microsoft Xbox 360 Elite Console - Black
3 red flashing light with blank screen not loading has to be turned off manually via console
  • 58 Answers
This is the RROD. It happens when the system overheats causing the solder to melt. The board needs to be reflowed. Check out http://www.wiredextreme.com or call 1-888-389-3038. We are a professional repair shop that can fix this for you. All of our repairs include a 90 day warranty.
Posted on Jul 05, 2010
  • 4 Answers
Not always the solder melting on chips u have to find out ur secondary code (4 digits) sites out ther to help u with that. My code was 0001 which is power supply problem. I found a short (solder bridge) under the usb ports. Shrts seem to be around the usb ports the most. Either pins are touching or a solder bridge etc. look close at board n u can see.
Posted on Aug 10, 2010
Screen goes blank and standby light keeps flashing red
How to fix ps3 yellow light of death 3. tips first
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then there are 2 options left for you on how to fix your ps3 safe and fast!
Send your playstation 3 back to Sony
You might think that this is an great option, but take a look at some statistics. Most users had to wait at least 4-6 weeks before they had their Console back. And also, if your warranty is expired, you have to pay a big fat $150,- to get the job done! Does this still sound as a good option?
Jul 27, 2010 | Sony PlayStation 3 40GB System
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
One red light on my 360
A Working Solution.
Remove any disk from the DVD drive.
Remove the hard drive and turn on. When you get to the dashboard turn it off again by holding the X button on the controller and select 'Turn off console'.
Wait 10 seconds and then turn on again by pushing the X button on the controller. When you get to the dashboard turn off again via the X button.
Remove the AV / Video plug from the back of your Xbox.
Replace the hard drive correctly.
Switch on the Xbox via the power button on the console. 4 red lights should flash.
Wait 10 seconds and re-insert the AV / Video cable.
You should now load into the dashboard with your hard drive profiles - wait theres more!
Turn off and on via the X button as before another 2 times with all leads and the hard drive in place.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again any way you feel like it and it should be cured.
May 20, 2009 | Microsoft Xbox 360 Elite Console - Black
Ps3 problem
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
May 03, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 shuts down as game loads
Generally there are a couple of things that can cause this. Bad installs of games, and more commonly thermal damage. The bad news is it will probably have to be repaired and Sony generally charges about $150 for that. Hopefully its under warranty? =)
There is some talk that the new firmware download may have altered physical parts that control the temperature inside the unit. Although that's just heresay i've been hearing more and more people thinking this is the case.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Video Game Consoles & Games
Wont turn on
.........same problem.....
only my new hard disk worked...
Aug 06, 2008 | Sony Playstation 3 (PS3) Console
1 red light
If it's the red ring of death get your reciept and send it to microsoft. all consoles that were bought in the end of 2005 till the summer of 07 are under warrenty. i hope you didnt take it apart.
May 03, 2008 | Microsoft Xbox 360 Console
3 flashing red lights
Have you tried unplug the system then turning it back on
if not you may need it repaired
https://service.xbox.com/servicehome.aspx
Dec 18, 2007 | Microsoft Xbox 360 Console
The classic 3 red lights issue
The garuntee for Xbox owners with the red light problem has been extended to 3 years. my advice is to get in touch with microsoft and they will take your xbox and either repair it or give you a new one, as long as you haven't tampered with the microsoft seal (on the insides of the console).
Hope this helps and good luck
(please rate if helpful)
Mick
Nov 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console - Black Logo
82 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
