Question about Lucent Cajun P333T Networking Switch
Hi, When I put an expansion card with a fiber port in my cajun P333T it blocks all ports. The switch is event not visible from the other in the stack. Can someone help me please ?
Try disabling the spanning tree
Posted on Jul 05, 2010
  • patrick_bout Jul 05, 2010
    How do i do to disable spaning tree ?
    Moreover the problem comes when I just plug the card. Nothing is connecting on the card
I need more ethernet ports on my router so I can connect another computer but I do not want to buy a new router. Can I put an expansion piece into my motorola 3347-02-1022 router? One that will add one or...
1. you can add a multi-port switch to one of the port on the router. this will give you additional ports. Beware of too many it will take up bandwidth depending on you broadband speed.
Sep 09, 2011 | Computers & Internet
Amber lights on a Cisco switch.
It sounds like you have loops in your topology. Loops will cause the LAN to crawl.
Amber, on a Cisco switch port means that a port has been blocked either as a security violation (if mac-address security is being used) or by spanning-tree protocol which shuts down ports involved in a network loop.
Check all your wiring carefully...especially the fiber-to-ethernet converters. If anybody has a hub or switch under their desk make sure they do not have two ports from that device patched into two ports in your cisco switch.
From Cisco catalyst 3500 user guide:
Solid amber
Port is not forwarding. Port was disabled by management or an address violation or blocked by Spanning-Tree Protocol (STP).
Note After a port is reconfigured, the port status LED can remain amber for up to 30 seconds as STP checks the switch for possible loops.
Nov 02, 2009 | Ortronics (MC62503)
Need to know the command line commands for Avaya Cajun P333t switches
cajun switches have pretty similar command structure as cisco. use the ? mark for help.
Jun 03, 2009 | Lucent Cajun P333T Networking Switch
Lucent Cajun not talking to cisco catalyst
Not sure what Cat switches you have, but the cajun switch must use the same trunking encapsulation.  Older catalyst switches use ISL trunking which only work with Cisco switches.  Make the port between the lucent and cisco dot1q encapsulation on the cisco trunk port.  Also turn on debugging on the cisco and see what messages are generated.
Apr 27, 2009 | Lucent Cajun P220G Networking Switch
Cajun P333T doesn't accept input from serial
All info from juliankov appears good.. but thought I'd add a bit of stuff I found on a web site..
http://www.tek-tips.com/viewthread.cfm?qid=300461&page=2
Use a console cable with following minimum pinout (the flat gray one with the RJ45- D9 type converter currently shipping with new P33xx switches will suffice): DB9 Console Port
1 ----------- 6
2 ----------- 3
3 ----------- 2
4 ----------- 4
5 ----------- 5
6
7 ----------- 8
8 ----------- 7
9
Obviously the speed is set to 9600
maybe stop all sessions & try to re-establish a new one. The instruction manual warns u can only run one..
Mar 10, 2008 | Lucent Cajun P333T Networking Switch
WS-GS5486
If you have device A connected to device B over a Gigabit link, and the link does not come up, perform this procedure.
Step-by-Step Procedure
1. Verify device A and B use the same GBIC, short wavelength (SX), long wavelength (LX), long haul (LH), extended wavelength (ZX), or copper UTP (TX). Both devices must use the same type of GBIC to establish link. An SX GBIC needs to connect with an SX GBIC. An SX GBIC does not link with an LX GBIC.
2. Verify distance and cable used per GBIC as defined by Cisco.
3. If either device has multiple Gigabit ports, connect the ports to each other. This tests each device and verifies that the Gigabit interface functions correctly. For example, you have a switch that has two Gigabit ports. Wire Gigabit port one to Gigabit port two. Does the link come up? If so, the port is good. STP blocks on the port and prevents any loops (port one receive (RX) goes to port two transmit (TX), and port one TX goes to port two RX).
4. If single connection or Step 3 fails with SC connectors, loop the port back to itself (port one RX goes to port one TX). Does the port come up? If not, contact the Cisco TAC, as this can be a faulty port.
5. If steps 3 and 4 are successful, but a connection between device A and B cannot be established, loop ports with the cable that adjoins the two devices. Verify that there is not a faulty cable.
6. Verify that each device supports 802.3z specification for Gigabit auto-negotiation. Gigabit Ethernet has an auto-negotiation procedure that is more extensive than the one used for 10/100 Ethernet (Gigabit auto-negotiation spec: IEEE Std 802.3z-1998). When you enable link negotiation, the system auto-negotiates flow control, duplex mode, and remote fault information. You must either enable or disable link negotiation on both ends of the link. Both ends of the link must be set to the same value or the link cannot connect. Problems have been seen when you connect to devices manufactured before the IEEE 802.3z standard was ratified. If either device does not support Gigabit auto-negotiation, disable the Gigabit auto-negotiation, and it forces the link up.warning.gif Warning: Disabling auto-negotiation hides link drops or physical layer problems. Disabling auto-negotiation is only required if end-devices such as older Gigabit NICs are used which cannot support IEEE 802.3z. Do not disable auto-negotiation between switches unless absolutely required to do so, as physical layer problems can go undetected, which results in STP loops. The alternative is to contact the vendor for software/hardware upgrade for IEEE 802.3z Gigabit auto-negotiation support
Feb 02, 2008 | Cisco (GBIC-LX/LH) Expansion Module
Base Switch 1601F
It looks like the 1601F (by LANTECH) is a rack-mountable 10/100 switch with a 100Mbps fiber module. Try this search (Newegg.com) for a list of possible replacements. (Note that several in the list have a 100BaseFX expansion port, but the module for that port may need to be purchased separately.)
More generally, if fiber connectivity, advanced management features, and rack-mountability are not necessary, you can just pick up a 16 port 10/100 switch at your local computer store. If you need more features but this is an emergency, you could pick up the lesser switch to use while you're waiting on the better one.
Jan 09, 2008 | LanTech 24 port 10/100 2 port SFP smart...
Duplicate/incorrect MAC addresses in the CAM table
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
Nov 09, 2007 | Lucent Cajun P333T Networking Switch
Help me with a Cajun p333t
it is reseting because it dosent have a lot of branwith
Sep 13, 2007 | Lucent Cajun P333T Networking Switch
How can I reset it back to original configration
Hey Eric, I do use same Avaya switch at my lab at office. To me what you have to do is quite simple, first of all you have to get from your network administrator the following info: - Free IP to assign to the switch - Subnet - Gateway (If you ping such IP from a machine of same subnet, there will not be an answer). Then log as superuser (#) and do this: 1. Type set interface inband Replacing , and with the VLAN, IP address and netmask provided by your network administrator and press Enter. (for VLAN you can list them and decide which one to use, but normally you should use 1) 2. Type reset and press Enter to reset the stack. 3. After the Reset, perform login again as superuser.  4. Type set ip route , replacing and with the destination and gateway IP addresses. (If you want all packets not from your subnet to be send to the gateway, then use 0.0.0.0 as destination, list routes set on device for more info) 5. Press Enter to save the destination and gateway IP addresses. That's all. Your switch will be rechable from your same subnet and from other networks if your gateway is working properly and there's no other element blocking you the access. Good Luck!
Oct 23, 2006 | Lucent Cajun P333T Networking Switch
Lucent Cajun P333T Networking Switch Logo
Top Lucent Computers & Internet Experts
D. E. Hev
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
