Question about Toastess TRC-18 20-Cup Rice Cooker
My Toastess 20-cup rice cooker stopped working right in the middle of a cycle. I tried a different outlet, and it still doesn't heat up, and doesn't even turn on. The unit is 6 months old.
  • Toastess Master
  • 43,501 Answers
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Posted on Jul 27, 2010
I have acquired a rival rice cooker 4310 and it won't heat up. It appears to be the power cord as it doesn't show any power flow with the multimeter on the heating element or the resistor. no...
There is a heat sensitive switch attached to the inner pot. It is very small, it turns the heat off when the pot reaches boiling temp. If it is open, replace it. They come in different temps, so get the right one. This one is supposed to open at 212 degrees, f. You will find a similar one in a Mr. Coffee, it switches the pot from boil to keep.
Sep 24, 2011 | Rival RC61 6-Cup Rice Cooker
The cooker clicks over to "keep warm" before the
You're probably using too much water. Rice cooks primarily while sitting in hot water, not while its boiling. That's why the cooker switches to Keep Warm so quickly. The correct way to cook rice is to pre-soak the rice for about 30 minutes, drain to get rid of the excess starch, combine the rice and cold water and bring the water to a boil and turn off the heat and let it stand for 15-30 minutes. That's why*- rice cookers take 45 minutes or more.
Sep 06, 2011 | Aroma ARC-914 8-Cup Rice Cooker
Completely stopped working. Plugged it in and the lights wont come on and it doesnt cook rice. Had it maybe right at a year.
Had mine 3 months and mine has done the same thing THREE times. ...with THREE different cookers!
Jun 10, 2011 | Rival RC61 6-Cup Rice Cooker
Started rice cooker it was on..when I went back to check on it it was off and won't turn back on. I tried unplugging the ricecooker and plugging into a different outlet but it still doesn't work. The rice...
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
heatman101
Apr 07, 2010 | Oster 3072 20-Cup Rice Cooker
My rival rice cooker does not work. i plug it in and try to turn it on - the lights don't turn on and the unit apparently doesn't heat up or work at all. tried different outlet - same result. should i...
It is a blown thermal fuse. On 6-cup Rival it is across terminal where power comes into cooker. You can replace thermal fuse for less than a dollar in under an hour. Remove the bottom of the cooker. The thermal fuse is covered by a heat wrap sleeve across input terminal.
Feb 09, 2010 | Rival RC100 10-Cup Rice Cooker
Rice is mushy, I have cut the water down by one cup and it is still mushy. 2 cups rice 4 cups water down to 3 cups water
If you are using regular rice, it is 1 cup of rice for 2 cups of water. Bring the combo to a hard boil and then reduce the heat to a slow simmer for 20min, stirring ocassionally.
If you are using "Minute Rice", it is 1cup of water to 1cup of rice. Bring the water to a hard boil, turn off the heat and add the rice. Cover for 5min. Fluff with a fork.
Feb 02, 2010 | Hamilton Beach 37532 20-Cup Rice Cooker
How many minutes for 2 cups of rice
The Wolfgang Puck BDRC0010 10-Cup Rice Cooker will stop automatically when the rice is cooked. The rice will be ready when the switch pops up to Warm. The average time would be about 20 minutes.
I hope this helps.
Nov 16, 2009 | Wolfgang Puck BDRC0010 10-Cup Rice Cooker
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
Cooking PLAIN rice
Here is my recipe - enjoy and please rate my answer as a fixya!
Raw Rice - 2 Cups (400 gms.)
Water - 6 Cups.
(The ratio of rice to water is 1:3)
PROCEDURE
Step 1:First wash the rice in water thoroughly and drain the water.
Step 2:Take a vessel ,the capacity of which is double the quantity of raw rice that is to be taken.
Step 3:Now,add the washed rice into this vessel and pour 6 cups of water into it .
Step 4:Now, place this vessel containing rice with water in a pressure cooker and add the pressure weight on the cooker top.
Step 5:Heat the pressure cooker for 20 minutes only.
Rice has been cooked.
NOTE:
*After heating the cooker for 20 minutes,donot open the cooker immediately.Wait for 15 minutes and then open ,otherwise the cooker would burst open.
Feb 16, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Why does it burn my rice on the bottom.
that is common to have the bottom part burn when cooking rice.
what i did was change the ratio of 5 cups water = 4 cups rice.
when its near cooking, dont leave it for a long time since it will continoiusly heat up in the bottom part, i suggest to unplug it when the rice is already cooked.
hope this will help.
Jan 15, 2008 | Rival RC100 10-Cup Rice Cooker
Toastess TRC-18 20-Cup Rice Cooker Logo
146 people viewed this question
Top Toastess Kitchen Appliances - Others Experts
ray gallant
Tom Chichester
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
