Question about Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation
Hoshizaki ice maker beeps when in the on position and will not make ice.
  • Dennis Boxerman Jul 11, 2010
    the number of beeps tells you what the possible problem is and what to look for. let me know and I'll give ya a hand.
  • Dennis Boxerman Aug 11, 2010
    need to know the number of beeps as this is an error code.
  • Hoshizaki Master
  • 1,252 Answers
The number of beeps indicates that there is a specific problem. Need model and serial numbers and number of beeps. On some models, the control board has a small white reset button on it. Just push it and see if unit will reset and run.
Posted on Oct 10, 2010
3 Suggested Answers
  • 4 Answers
SOURCE: Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
Posted on Apr 03, 2010
imufo2
  • 3773 Answers
SOURCE: trouble ice maker
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 16, 2011
Hoshizaki Model B-700PF is beeping three times and wont make ice.
It appears that you have supplied the ice bin model number and not the ice maker numbers. Please double check your unit and see if you can locate those numbers.
Dec 11, 2017 | Hoshizaki Freezers
Why isn't my Hoshizaki km 630 mkh ice maker not making any ice?
that could be a number of problems..is it making any beeps or flashing lights on the circuit board? Have you tried to reset the circuit boards reset button with the machine on. ? If the machine seems totally dead then the bin thermostat is most likely the problem..
Aug 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-630MAB
Check your refrigerant pressures during harvest. The board is picking up a fault. You could have a thermister problem on the suction line.
Jun 26, 2014 | Hoshizaki Kitchen Appliances - Others
How to reset Hoshizaki ice maker ?
If you just want to reset it because it is making a beeping sound, there is a small white button on the control board. just press it while the power is on. If you want more than that, please supply more info.
May 25, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker not making ice. When pressing the test button will start to make some and then beep about 3 times, then does not produce anymore ice.
Do not use test button. It test the functions of the board only. You have another issue. Need to know the number of beeps. Usually beeps a certain number of times, then hesitates,then beeps again.
Jul 27, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a hoshizaki ice machine and it will harvest for about 3 harvest and just before the 3 harvest it shuts off. It makes us up untill it shuts off. It beeps 3 times. DONT know what to do! NEED SOME...
How long is a freeze cycle on your unit? How big are the cubes that it's dropping? The three beep error indicates that the unit exceeded maximum freeze time.
Sep 05, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
Feb 19, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
Machine beeps when turned on ice position cleaning cycle works but no ice is beeing made
first try resetting the board by pushing the reset button on the board. But make note of the number of the beeps before resetting.
Dec 21, 2009 | Hoshizaki KM-630M Crescent Cuber Ice Maker
Hoshizaki ice/water unit beeping-unit new-operating 1 month
800-233-1940 is our tech. support or look at
http://www.hoshizakiamerica.com/techsupport/tech.asp?
Apr 08, 2009 | Hoshizaki Cubelet Ice MakerDispenser Water...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Logo
205 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
