Question about Vizio L37 Television
The tv screen has black edges on both sides of the screen. It cuts off about four inches on either side.
dave1645
  • 834 Answers
SOURCE: Orange 2 inch line appeared on left side of screen ,then no pictu
it could be jusr a bad connection on th LVDS cable or your panel has died
have a tech check it out or send it to Tops Electronics in Haverhill ma
Posted on Nov 18, 2009
jan mczeal
  • 632 Answers
SOURCE: my 50 inch zenith plasma tv model number Z50P3
The problem lies in the X-Drive boards or the TCPs (tape carrier packages) and they are not serviceable. Once faulty the X-Drive boards must be replaced. The worst scenario is a bad TCP because it indicates a bad panel and you have to replace the panel.The X-Drive boards deliver color information to the vertical grids of the panel through the TCPs. That's why when a fault occurs in the TCPs, vertical black bars appear on the screen and an a much larger part when an X-Board fails. Your TV uses three of these boards, one each driving the right, center and left portion of the plasma panel. The left X-Board has eight TCPs and seven to each of the right and center X-Boards. In your case, the vertical grids driven by the center X-Board is dead but you can't tell the board has failed, It is due to the fact that both the right and left boards are okay but only two TCPs are good on each of them. Meaning there are six bad TCPs on the left board and five on the right. Remember a bad TCP indicates a bad panel and you have at least eleven bad TCPs. The only solution here is buy a new panel or probably a salvaged one auctioned on ebay or have your set or its parts auctioned on ebay then buy a new plasma TV.
Posted on Dec 04, 2009
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
I had one vertical line it cam and went for awhile then stayed permanently and I took it in for repair only to be told they couldn't fix it now they are trying to give me a used tv (warranty don't want to pay) but I refuse I purchased it new and I told them I want a new one. I had that tv less than 2 years. So if you have a warranty and lines get it in fast.
Posted on Mar 26, 2010
nvdlpsvc
  • 53 Answers
SOURCE: black line down the side of both sides of the
mitsubishi covers this problem under ext mfg warranty for two years after date of purchase 1800 332 2119
Posted on Mar 27, 2010
SOURCE: Vizio 46 inch black screen on left side
Sounds like you either have a faulty LCD panel tab, failed LCD driver board, LCD/t-con panel bad connection, or a bad t-con. You will need to get a diagnoses to be sure.
Posted on Dec 16, 2012
How can above ground pool be repaired
It sounds like the hole is relatively small. You can make a patch using a piece of sheet metal or a piece of flat aluminum which you can purchase at Lowes or Home Depot in the hardware dept. Use sheet metal if the metal surround is metal. Use aluminum if the surround is aluminum. You can tell which is which by taking a magnet and touching the metal. If the magnet sticks, it's metal not aluminum. Cut the patch using sheet metal shears to a size that is 4 inches by four inches larger than the hole. Then you'll have two inches on each side of the hole. You are going to need to put the patch on the inside of the metal, between the liner and the metal surround. This so the hole edges won't tear the liner. When you cut the patch, round off the edges so there are no sharp edges. Take duct tape and cover the edges of the patch. Place 1/2 the width of the duct tape and apply it to one side of the patch and fold the other half over to the other side. You can cut a round patch, but a square or rectangle patch will be easier. Just cut the corners round. Purchase a small tube of silicone sealant ( when you but the patch material) and apply a bead around the patch edges and in the middle. Then affix the patch over the hole. Wipe off any sealant that ozzed through the patch so it doesn't bond to the liner.
Jun 01, 2014 | Karcher 2500 PSI Pressure Washer
Right edge fades to black (Approx 2")
ok! you have defective horizontal linearity check horizontal section then check capacitors! like 180uf 200v or 200uf 200v. the problem is defective capacitors!
Sep 28, 2007 | Toshiba 44NHM84 44" TV
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
Vizio 32 inch thin black vertical line on left side of screen
it is very likly you have problem with the buffer boards, sometime help to unplug conector and reconect, also check the smd fuse located on one of the boards since there are 2 buffer E&F.
Jan 09, 2013 | Vizio 32" Lcd Hdtv E320VA Hdmi Hd Tv Flat...
I don't know how to turn it on
It is my pleasure to guide you.
Look along the right side edge, 1 inch or 2 inches back from the screen edge. There should be four or five buttons and the bottom one should be the on/off button. Just press it and the
TV should turn on. Of course I don't have to mention to be sure it is plugged into a live outlet.
Please post back that you are successful or that I can be more helpful.
Jun 05, 2011 | Televison & Video
A four inch vertical black screen on the right side of tv
Im Pretty sure in the menu screen there is an adjustment, That is assuming that the picture is adjusted to far to the left, Go to a Tv guide channel and try reading, See if you can read the complete listings?
Apr 10, 2011 | LG 32LG30 32 in. LCD HDTV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Vizio L37 Television Logo
122 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
