Question about Apple MacBook Mac Notebook
My computer screen gets all broken up, and it freezes. I can hold the monitor at an angle, but as soon as I let go it freezes. If I push it all the way back, sometimes it works uninterrupted, but sometimes not.
  • 502 Answers
Sorry but your lcd panel needs replacement. Take it to the apple store and see if they'll give you a replacement. If they don't there are third party Macbook Repair services that can fix it for you. There are also free Macbook Repair guide that show you how to fix it yourself. The part is on Ebay.
Posted on Jul 10, 2010
Monitor goes blank after 5 seconds, what do i need to do?
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 18, 2010 | Samsung T220HD LCD Monitor
I am having problems with my screen on my hp dv5000 notebook. The bottom have of the screen will freeze and only the top part is scrolling down and moving. After a while my screen will start to get lines...
the fault could be from your laptops graphic card.
Connect your laptop to an external monitor, and if the screen still freezes on the external monitor, then the fault is truly from your graphic card.
But if the external monitor displays well, then it means the problem is from your screen inverter.
From which ever angle the fault may be coming from, you need to take the laptop to a repairer to fix the problem for you. I don't think either of the fault is what you can handle.
Take care.
Apr 14, 2010 | HP Pavilion dv5000z Notebook
The monitor goes off after being on for 2 seconds
Tough one. You will need some good skill to do this on most monitors. There are likely several lamps if the screen is larger than 14".
Try here for parts:
http://www.73.com/a/0740.shtml
I have not dealt with them.
Be aware you will get dust in th LCD and it will be VERY hard to clean.
Mar 29, 2010 | Dell E173FPb 17" TFT LCD Monitor
How to angle the monitor
I have Model X203H & had the same problem. The support CD explained how to adjust the monitor:
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Apr 16, 2009 | Acer 22" X223w LCD Monitor
Monitor randomly shuts off and computer restarts
After you turned it on and the screen shut off, check the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If the computer shut down immediately after the monitor shut off, it might be because of fault operating system. Check with another monitor.
Thank you,
Mar 08, 2008 | HP Compaq FS7600 17" CRT Monitor
Screen went black
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. You have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside. Some of them were broken and it is very easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. You might go get technician to do fix it.
Mar 06, 2008 | Sony SDM-HS75P/S 17" LCD Monitor
Kogi l4ax monitor (black screen)
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went blank, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. You might go get technician to fix it. Hope this help!! If anything I can help you with, feel free let me know.
Thank you,
Tan
Mar 06, 2008 | Kogi l4ax 14.1" Flat Panel LCD Monitor
My Videoseven Monitor is just displaying a white screen (or sometimes grey) It does not respond to the computer.  I know its not the wires or computer as I have changed the monitor to another one and the...
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burning spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 06, 2008 | Videoseven V7 E17PS 17" LCD Monitor
Screen tiled and i can't move it back
Try reseting the settings to factory defauts in the monitors user menu. You can get more details from the manual on this.
If reseting the settings doesnt work. Could you take a photo so we would have a better understanding of the problem :-)
Or do you mean the screen is fysically tilted? If parts are broken and you are unable to move the screen, then I cant offer much help, you could contact acer for support or to take it to a local pc shop for analysis.
Feb 08, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Apple MacBook Mac Notebook Logo
130 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
