Question about Intel D845GVSR Motherboard
My computer does not start at all and there is a long beep sound .pls help what to do?
  • 60 Answers
Check the power supply.
Posted on Jul 05, 2010
  • lallison1964 Jul 06, 2010
    Here are a few codes for you...
    Guru:
  • 285 Answers
Check ur ram bank and ram clean ur ram pind with a eraser and then try till u clean remove cmos batt befre u clean if still prob is there replace ur ram
Display problem, CPU Fan starts but no Power on self test begin. Pls help
The computer power-on self-test (POST) tests the computer to make sure it meets the necessary system requirements and that all hardware is working properly before starting the remainder of the boot process. If the computer passes the POST the computer will have a single beep (with some computer BIOS manufacturers it may beep twice) as the computer starts and the computer will continue to start normally. However, if the computer fails the POST, the computer will either not beep at all or will generate a beep code, which tells the user the source of the problem. Once the problem is located, simply replace the defective part.
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep CodeDescriptions1 shortDRAM refresh failure2 shortParity circuit failure3 shortBase 64K RAM failure4 shortSystem timer failure5 shortProcess failure6 shortKeyboard controller Gate A20 error7 shortVirtual mode exception error8 shortDisplay memory Read/Write test failure9 shortROM BIOS checksum failure10 shortCMOS shutdown Read/Write error11 shortCache Memory error1 long, 3 shortConventional/Extended memory failure1 long, 8 shortDisplay/Retrace test failed
Jul 27, 2011 | Gigabyte Computers & Internet
My house power went off and when it came back , i am not able to switch on my desktop. All i hear after i power on my desktop is the fan noise and the beep sound. Pls help
If you hear exactly ONE beep, it means that your computer-hardware (power-supply, CPU, motherboard) is OK.
Multiple beeps are "bad" -- they identify different errors.
If Windows does not "boot", then the power-surge may have damaged your 'C:' drive. Ouch!
Jul 18, 2010 | Dell Inspiron 530 Desktop Computer
My computer beeps but it beeps like a robotic sound..
exchange the memory in different slottt. clean the memory slotss and clean the memory with pensil eraser only the gold pinss., then insert them back in, if u can take the fan off and cpu check if its burned or anything then insert it back..
Feb 22, 2010 | Gigabyte GA-K8VM800M Motherboard
Starting proplem
The one beep is normal . If the fan is not working on the CPU , replace the fan or oil it The CPU can go only a second or so without the fan working. Some models(BIOS )will not allow the computer to start if the fan is not working. Start there.Check out the link below:
http://www.computerhope.com/beep.htm
Jan 19, 2009 | Compaq Presario SR1000T (568657) PC...
Try to start my computer but tower keeps on beeping and monitor keeps saying going to sleep. What could be the problem?
Probable reason for the beeping sound are:
  • defective, dirty or faulty seated memory sticks; clean, re-seat or replace (most likely);
  • defective, dirty or faulty seated video card; clean, re-seat or replace (likely);
  • corrupted BIOS; flash or replace motherboard (least likely).
The monitor going into sleep mode is because it does not sense any usable video signal from the computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Computers & Internet
My computer does not sart
Initially I would suspect hardware failure on your PC. The only user action possible would be to open the PC and look over the memory sticks and the video card (if not built-in). Remove them and clean the little gold pin edges. Additionally, it might be of help to clean the slots where they go to with the use of a clean dry paint brush. Soon as everything is cleaned, reinsert the memory and/or video card to their respective slots. Power up your PC. If it runs OK, you're set to go if not, pls determine if you can hear a series of beeping sounds. Pls post back describing the sequence and duration of the beeps.
May 04, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Pls help!
you can use bluetooth to do the transfers without the use of cables.
you can do a master reset type *2767*2878* that should erase the beeping sound
Nov 06, 2007 | Samsung SGH-e315
HP desktop wont start up
Hi, depends on the beep sequence, it could either ba a bad memory or a bad video card. By being bad does not necessarily mean defective but could possibly be just loose. Try to open the casing/cover and reseat/push back into place the video card (if it is not built-in) and/or the memory. It is possible that they were jarred loose while in transit. Pls make sure the unit is unplugged before doing this. BTW, being new, you might void your warranty if you open the casing, pls check your warranty card. Hope this works out for you. Please let me know how things turn up. Regards
Apr 12, 2007 | HP Compaq dc5100 PC Desktop
Intel D845GVSR Motherboard Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
