Question about Mitsubishi WD-65733 65" HDTV
Green timer light blinks and then lamp light blinks.. tv will not start up.
  • 58 Answers
You probably need a lamp. Check the code by holding menu and input for 5 sec. If you need a lamp the led will flash 6 times pause then flash 6 times again. The code will repeat several times if you miss the first few flashes. If the code is different, let me know what it is and I can help you. Thanks.
Posted on Jul 06, 2010
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: WD 62725 Timer geen light keeps blinking
Thats caused by the capacitors on the dm which wont allow the DM to boot back up because the power cord was unplugged to change the lamp. You can get the V26 DLP DM repair kit at the following link which will usually repair that issue and it contains the replacement caps and step by step instructions with detailed pics on how to do the repair on CD plus the service manual is also on the CD.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Posted on May 26, 2009
  • 668 Answers
SOURCE: Mitsubishi DLP, green blinking timer light, tv won't come on,
This Chassis has been known for a slew of Capacitors failing throughout many of the Circuit Boards. The best way in my opinion to fix the set is to send the Chassis Assy to Mitsubishi for them to rebuild it. Some folks have has some success in replacing the bad Capacitors in the Power Supply, the DM Board, and the Format Board to get the set to turn on. These Capacitors are identifiable because the tops of them are bulging up.
It is a difficult set to work on and disassemble, this is Mitsubishi's Customer Service Number in case you need assistance. 1800-332-2119
I hope this helps,
Sky Assoc
Posted on Feb 08, 2010
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I have a Samsung HLT5076S DLP Tv and when I turn it on I get a blinking Green Light for a couple of Mins. Then after awhile all three light start to blink. The standby light is Red and the timer and the...
It is the lamp but try to check the filament of the lamp if defective because if the color wheel is defective you will hear a whirring noise. Try to check the lamp if defective replace it and if you replace the lamp you should reset the lamp hour meter, feel free to send feed back good day and best regards.
Aug 22, 2011 | Samsung HL-T5076S 50 in. TV
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
The green light blink for a while and then shuts off and the lamp light blinks once red???
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
I hope that helps.
Mar 20, 2010 | Panasonic PT-52LCX66 Projection Television
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
Mar 26, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Mitsubishi WD-65733 65" HDTV Logo
211 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
