Question about Canon Laserbase MF6530 All-In-One Printer
Canon mf6530 crumples paper and makes grinding noise when trying to print.
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: Canon mf6530 crumples paper and makes grinding
I pressume that paper is wrinkled in fixing section. Probably the fixing bushings are worn out. The grinding noise could be from paper when it stuckes, but also from gears.Call service.
There is a trick if paper is moisturized. Flip paper in cass. up side down, and try again.
Posted on Jun 14, 2010
Testimonial: "Great suggestion But need to know where the "fixer" is? I downloaded a service manual but I am use to fixing computers."
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
I use my MF6530 Laser Copier Printer to print checks and it will frequently print on the reverse side of the paper.
hai I give print to printer 2 side in single page, first two page print well but another two page print in opposite direction in the same paper (example1,2 page one side and 3 ,4 pages in other side but reverse direction. it mean you turn the paper to next side, you see opposite direction ) please help me to avoid this problem.
Jul 22, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Jun 14, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
Paper feed jams, and when tray is inserted, the top sheet is pushed forward and crumpled along the front edge.
sounds like you have something obstructing your paper path,before inserting the tray check to see if the sensor is freely moving,hope this helps
Jul 07, 2009 | Canon Laserbase MF6530 All-In-One Printer
Printer doesn't put image on paper
The laser shutter is bad or stuck. The new one is redesigned. The shutter could be removed but that would break saftey laws. If its under warranty still have a repair center do it.
Mar 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Crumpled paper comes out of copy machine
Firstly make sure that in the cassette the paper tray guides are fully against the paper as if they are not the paper will wiggle through the machine and cause your fault. If this doesn't work then check the paper path as there maybe a small piece of paper causing it to shift and turn causing the crumple. Also check the fuser and the little plastic stripper fins as they may have dried toner on them causing the fault.
Hope this helps you
Thanks J
Jan 08, 2008 | Office Equipment & Supplies
Canon imageClass MF6530
This is a "monochome printer" ie B/W, double sided is called duplex select this option on printer driver on pc
Dec 01, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Sep 17, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Laserbase MF6530 All-In-One Printer Logo
49 people viewed this question
old marine
old marine
