Question about Brinkmann Charmglow 810-7600-S Grill
Putting in new burners what do I set the vents at. All the way open, half closed or just barely open?
  • 140 Answers
Shut them 3/4
Posted on Jul 07, 2010
I have a reznor gas unit heater gravity vent Burners new. Burning back into burner only one dose it Pressure good
Check the air shutter adjustment on the burner, it may be too open or too closed, which could be causing your problem. If it does not have an air shutter, the manifold may just be too close or far away from the burner. Make sure it is free of cobwebs too.
Feb 13, 2015 | Grilling
Why won't the burners light even when I smell gas and hear igniter clicking?
Bill, two things possibly going on here that are common with an aging grill. First you need to turn off the fuel tank and set it aside. you mention that a clicking can be heard when pushing the igniter button which usually indicates good battery but if you have never changed it you may want to just as a good measure. Unscrew the bottom and you should find AA or AAA battery behind it. Now with battery good and the igniter generating a fast load clicking sound you want to get down and follow the wire that runs from the the back side of the igniter push button down inside and usually under the burner tubes ending out at one end of each burner. What happens when you press the igniter switch is, an electrical current is sent down the wire and when it reaches the end the current jumps to the closest metal it can find creating a spark.so you need to insure that the end of the wire is close to where the flame is generated but not so close that that you cant see a spark. Make sure the end of the wire is bare and clean as is the area on the burner where it arcs Now do this to all for burners. Turn all the knobs on the grill off and connect the tank. Make sure the lid is open now, and slowly open the valve on the tank. I say slowly like a ten count from close to full open. what can happen if you crank the tank valve open too quickly or with the grills valves open a vapor-lock effect can be created greatly reducing the flow of fuel from the tank. Iv'e seen many of the uninformed return 1/2 full tanks due to this problem. If you notice week flame or no flame but smell gas ALWAYS SHUT OFF VALVE ON TANK IMMEDIATELY KEEP LID OPEN AND LET THE AREA VENT BEFORE TRYING AGAIN lest you be the one being barbecued. Good Luck
Apr 27, 2014 | Kenmore 16225 Grill
VERY LOW HEAT ONCE LIT. TAKES EXTREMELY LONG TIME TO COOK ANYTHING AND THE FOURTH BURNER DOES NOT LIGHT
The new propane bottles have a safety device in them that shuts down the gas if it senses the gas is going out the bottle too quick. Thank you Ralph Nader. To remedy this yall shut all valves off and remove the tank from the grill. Open and close all valves just for fun making sure all of them are off. Then reconnect the tank to the grill and SLOWLY open the triangle shaped valve to just bare ly open, maybe half a turn or less and then retry. More here
Jul 01, 2011 | Brinkmann Charmglow Stainless Steel LP...
I have a maytag super capacity plus stove and need to adjust the air mix for the burners. How to do it? Please help thanks
Open the top of the range. I believe there are a couple of spring clips in the front between the range top and the top of the door. Not sure on the Maytag. However, when you get the lid up, (it should be hinged at the back), set the burner pieces back on. (These burner pieces HAVE to be there or you'll just have a blowtorch pointing up!) You'll see that going to every burner there is a tube to carry the gas. on the side of every tube there will be an adjustable, sliding air vent. They are usually held in position by a set screw. Loosen the set screw. Light the burner and carefully slide the vent closed or open to adjust how much air is being brought into the mix. If the flame is way too high and or orange in color....you have too much air. You want as much flame as possible on high without the flame being orange or white-ish. Once you get the flame the way you like it, tighten the set screw back. Hope this helps.
May 15, 2011 | Microwave Ovens
I've got a 23 yr old 30DV3 whose pilot light works, and the thermostat & heating element seem to work, but not well. With the thermostat set at full hot, it just barely throws out any heat at all. ...
As I'm sure you already know, Empire Comforts Systems, no longer makes that model heater and hasn't for some years, now. I mentioned that, because if your unit needs parts, they may be almost impossible to get. In any event, there are a several things that may be causing the problem.
  • Low Gas Pressure - Burner is not receiving enough gas. Check for obstructions and have gas pressure at the unit checked.
  • Clogged burner or air intake (venturi valve) is partially clogged. Clean burner ports and venturi valve.
  • Gas line Shut Off Valve at heater not fully open. Check Gas line Shut Off Valve.
At 23 years old, you've gotten your money's worth out of this unit and it may be time to replace it. Empire makes several Direct Vent Wall Furnaces that are rated as High Efficiency Furnaces. In the long run, the money saved in fuel cost, would be worth installing a new one.
Hope this helps you solve the problem.
Apr 11, 2011 | Empire Direct Vent Wall Furnace;...
I've got the 20050106 and simply can't stop my wood chunks from catching fire. I've soaked them from anywhere from a half hour to 6 hours...I've put them in aluminum foil. I've kept the temp at 200. Is...
You need to shut down the air intake, that is most likely your problem. Fire can't start without oxygen, but the wood will still smolder and make the delicious smoke you are looking for. Close all the vents, then adjust them as you smoke.
Hope this helps!
Jan 18, 2011 | Masterbuilt 20050106 Propane Smoker
I put in a new full propane tank tonight, and the grill seems not to be getting any gas. The valve is open and it worked fine last night. Any suggestions?
Ericksen,
Pull your burners out. Make sure the gas is off at the tank.
At the bottom of the burners there is a pipe with little doors, If those doors are closed all the way, Open them half way and they usually have a locking screw. tighten screws and put back together.
When doors are closed, only gas is expelled. Without air it is less flameable. You need air and gas to create a fire.
OK
Jul 31, 2010 | Weber Genesis E-310 Gas Grill
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Brinkmann Charmglow 810-7600-S Grill Logo
55 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
