Question about Polaroid SprintScan 35/LE Film Scanner (35 mm)
I have an old polaroid sprintscan film scanner model 35/le. I want to connect it to my laptop that has 15 pin male connector and USB 2 sockets. The Scanner output is from 25 pin female connector. I need a cable to connect the scanner to laptop. Do I connect it using 25 pin male connector cable to 15 pin male connector. Or I should use 25 pinmate connectro cable to usb2. I am un able to find a supplier who would sell such cable. I am not sure which one to buy and where from. Do I need an up to date software the driver. Thnaks
  • akhtar933 Jul 05, 2010
    Sorry. I am already awaare that i neded such cable but the problem is I can't find it from anywhere in UK. The original cable that came with it gone missing. Polaroid has discontinued this model and won't sell any part or accessory.
    Can it be connected using 25pin male to usb2 connector cable insead. If so is there such cable readily available from computer shops.
    Thanks
    i THINK THERE ARE VGA CONVERTER AVAILABLE THAT HAS 25PIN MALE TO 15 PIN FEMALE. I don'nt know if this will work if I find another cable to fit at 15 pin female end and has 15 pin male on the other end. will it solve the problem.
    Thanks
    Master:
  • 515 Answers
You can use the 25 pin to USB converter. It is available through the following link.
http://www.amazon.com/CPA-1030-Converter-Adapter-Coverter-Magellan/dp/B000S5F4MQ
Posted on Aug 09, 2010
  • Polaroid Master
  • 8,404 Answers
My friend ... before you do anything else ... go here and see if the printer is supported by the operating system you are using on your laptop: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If it is listed, there will be a driver in your OS or elsewhere that will drive the printer and/or additional instructions.
If you are listed, great. you will know what to do.
If you are not listed - save your time, you will not find a driver unless you make one (very few exceptions)
Now then ... if you find the hardware listed on the hardware list ... someone makes a cable or an adapter. I suspect you will find a adapter that fits into the 25 pin female and has a USB out put ... or you will find a 'print server' that will do the same. Expect to pay $40.00 or more for a server.
Good luck and thanks for your interest in FixYa.com
Posted on Jul 05, 2010
  • A Miller Jul 05, 2010
    Hi there again, ... I see your qestion is back again ... Have you checked the hardware list as I suggested? I did - I didn't find your hardware listed under Windows 7 ... though you dont list the OS you have on your laptop, if you are tunning 7, your machine is not supported as far as I can tell.
    President:
  • 4,070 Answers
Hi! You will need a converter cable that has a 25 pin male connector and a 15 female connector to connect to the laptop. This may not be easy to find but there surely is. Try visiting some computer surplus parts store. THey may have what we are looking for, they always do. Hope this helps and have a good one!
  • 1 more comment
    Thank you for posting me solution but I have already done so, I can't find any computer shop or accessory shop who has such cable. 25 pin mate to 9 pin female is the one readily awailable. I have also tried to find gendefr connector but no success. I am stuck. I don't know if the scanner can be connected to the lap top using a cable that will have 25 pin male to usb2 end. Is there such cable readily available and will it work.
    I have got with me a 25pin male to 9 pin female cable but it can not be used because lapto has female connector of 15 pins for vga only.
  • dj_relly999
    dj_relly999 Jul 05, 2010
    There could be one available on the computer stores, might want to check it out.
  • dj_relly999
    dj_relly999 Jul 06, 2010
    Try it, it may do it.
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
SprintScan 4000
paul here i am, what happened, you suddenly ended our session, do you still have the script? we can continue it there if you want. just watch out for my reply.
Jul 30, 2008 | Polaroid SprintScan 4000 Film Scanner
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If this is the monitor cable you have, you need this type of adapter,
http://www.directron.com/dviadapter.html
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
PROBLEM CODE-'LE'
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective.
Jul 25, 2010 | Kenmore 24032\24036 Top Load Washer
I need to connect my Lexmark X3650 to my laptop - but a standard usb lead doesn't fit. I need either a usb to usb connector or usb to 15 pin connector. Can you help?
hi: the 15 pins conector are display connector on laptops.
if there are posibilyti for pcmcia card you have a chooice of manny
usb /fire wire/serial/network/modem/ and so on or if the printer have centronics connection then you have to buy a usb to centronics thad wil also connectable to pcmcia card
Nov 01, 2009 | Office Equipment & Supplies
Cant get my computer to recognize my SprintScan 4000
The scanner uses a "twain" driver, try searching for that, it may be one of the files you already downloaded. Just look in the download u got.Also try going to add hardware, select the scanner there and poit it to the downloaded file when uit asks if you have a disk that came with it. Download the drivers to your desktop, rt click and open a folder on the desktop, and drag all of the drivers and the Twain one especially, into the folder.
Feb 06, 2009 | Polaroid SprintScan 4000 Film Scanner
Polaroid SprintScan 35/LE Film Scanner (35 mm) Logo
142 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
Joseph Gallucci
Jonathon summesfield
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
