Question about Brother DCP 115C All-In-One InkJet Printer
Not printing black
Hi, printer has been great and reliable , but its not printing anything black, aaah, any one help? Natalie
My printing blur green not black, please solution
Posted on Jul 13, 2010
Is their anything else I can do to fix the problem?
Go to settings, reset the type of picture and text to be printed. If this doesnt work you can now get a new printer for a great price on Amazon these days.
Jun 12, 2017 | Kodak ESP C315 All-in-One Printer
I have a Canon MP730 and it has always worked great - until. I ran out of black ink and replaced tank. Tried to align the print head, but none of the black samples are even close to being a solid color -...
Hi There,
I believe that the printer head which feeds the ink dried out and clogged at the ink dispersal point. I'd suggest you take it to your nearest printer service capable repair center and just have them unblick the clog.
Regards,
Selk
Mar 25, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Which printer should I use
I don't know anything about screen printing, but is there a reason that you can't use a monochrome laser printer for your Black and white...The cost per page is at least 15-20 times less! Especially if you go with HP and get remanufactured cartridges from a reputable source.
Apr 23, 2009 | Epson Stylus 2200 InkJet Photo Printer
MFC-440CN printer. Colors are not proper
I'd like to help if I can. These printers have 4 cartridges. One black, one magenta (reddish), one cyan (blue) and one (yellow). The text and pictures are printed with a combination of these inks. When one or more is low, printing will be as you described. Your situation seems to be that you are out of black (so the cyan is trying to help and can only print blue) and you are probably out of yellow so the magenta is trying to do what it can. If you'll change all of the cartridges, I am pretty sure that you will have your problem solved.
Finally, there is a great place to get cartridges for your printer. The link is:
www.monstertoners.com/dcp-130c.html?gclid=CN2s_uiEsJgCFRIcawodQz_rUg
You can buy a multi-pak consisting of 4 black and 2 each of the three colors for $39.95 plus s/h
I use the cartridges and they have proven to be reliable.
If my help has been satisfactory, please give me your rating.
Jan 20, 2009 | Brother Multi-Function Center MFC-240C...
White vertical lines on printed page
change the k black drum... its the only solution trust me
thanks
Nov 19, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
HP z2100 horizontal lines where the text or object are
Check for updated firmware and drivers. Also, if all your object and text or black try changing them to color and see if that helps, maybe there is something wrong with your black printhead, the black may not be used when printing photos, the printer may be using process black for photoes and real black for black text and objects.
Oct 08, 2008 | HP DesignJet Z2100 InkJet Photo Printer
Hp940c print problem
Hi, I have had this happen before, try holding down both the power and ink replacement buttons at the same time. After about 5 seconds let go and it should shut down then try turning it back on....hope it helps
Jan 14, 2008 | HP DeskJet 940c InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
140 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
