Question about Wharfedale Moviestar 60+ System
RCA Jack Please specify RCA jack model to connect from a Wharfedale Moviestar 60+ Subwoofer to an AV Receiver
3 Suggested Answers
SOURCE: Wharfedale Moviestar 60+...
witch company your sub woofer. aleredy company has given user manuval see connections in manuval okkk
Posted on Mar 15, 2008
VOTIT
  • 2071 Answers
SOURCE: dont know how to connect
Just click and choose whatever hooked up connection you want; DVD Players/Recorders: Home Theater Setup, Installation & Hook Up .. * Audio and Video Connection Guide * What is HDMI Technology? * HDMI Explained in Detail * Audio and Video Definitions Plasma or Video Projector Wiring Guide Blue-ray Surround Wiring HP TVs - TV Cable and Connection Types Hope this may help; Regards, VOTIT
Posted on Jun 08, 2009
How to install/wire an RCA jack in Sony SA-WSIS10 Powered Subwoofer?
This link will allow you to download the manual for this system ... from there you may be able to figure out the solution or take it to an electronics expert for further advice.
Jul 24, 2013 | Sony Sa-wsis10 Sawsis10 Sub Woofer For...
How do I eliminate the humming on my Vizio VHT-510 system
see this instruction and fix it. God bless you
    • 1
      Disconnect the coaxial cable at the back of the satellite receiver or cable box by unscrewing the coupler on the cable end.
    • 2
      Attach the cable to the RF IN jack on a surge protector and tighten the coupler clockwise.
    • Sponsored Links
    • 3
      Connect a second coaxial cable from the RF OUT jack on the surge protector to the input on the cable box or satellite receiver. If this stops the hum, congratulations: You're done.
    • 4
      Unplug the subwoofer's electrical cord from the power strip or wall outlet if it is connected to the same circuit as the AV receiver. The amp in the AV receiver and the amp in the subwoofer are in conflict over the grounding of the electrical circuit.
    • 5
      Plug the subwoofer into its own surge protector and connect the surge protector to a different wall outlet than the AV receiver uses.
    • 6
      Disconnect the subwoofer cable from the back of the sub and the AV receiver if all other measures fail to stop the humming. Reverse the plug connections so the plug that had been connected to the receiver is now connected to the subwoofer. Turning the cable around may solve a problem known as ground-loop hum by reversing the shielding wire inside the cable.
Read more: http://www.ehow.com/how_6979184_eliminate-sound-home-theater-subwoofer.html#ixzz2ZdzrgBSa
Jul 20, 2013 | Vizio Vht210 2.1 Home Theater Soundbar...
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
When I connect my Wharfedale Moviestar 50 subwoofer to my receiver, it doesn't give out any bass. I tried turning up the volume, but all I heard was a deep rumble when I turned the knob. This is very...
I suspect your receiver is no longer sending out signals to it. Try adjusting the speaker settings and see if it has been turned off or is too low.
By the way some receivers have settings for late night listening, so you don't have to switch things off. Check your manual to see if your Receiver has these settings.
Jul 01, 2017 | Wharfedale Moviestar 50 System
How do I hook it up to my Surround sound reciever?
Hooking up a subwoofer is dependent upon what hookups are availble on the receiver and subwoofer. Does your receiver have a specific subwoofer output? If so, is it set of speaker-wire terminals, or is it an RCA jack? The Wharfedale can accomodate either one of these as an input. There are four speaker posts on the back of the subwoofer, and there is a single RCA jack input.
May 16, 2010 | Wharfedale Topaz SW-10 Subwoofer
Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Feb 16, 2009 | Onkyo HTR500 Receiver
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Subwoofer.......
    Please check your model number, I can not find it on the JVC service website.
    This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
    The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
    If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
    If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
    Dave
    Nov 10, 2008 | JVC SPPWA670 Subwoofer
    Subwoofer
    You have the subwoofer plugged into ac and you see a light? parhaps the RCA cord is bad. Try another one.
    Jun 09, 2008 | Sony STR-DG800 Receiver
    Wharfedale Moviestar 60+ System Logo
    21 people viewed this question
    Top Wharfedale Audio Players & Recorders Experts
    jason
    Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
