I have a samsung 403t 40" flat screen monitor. Is it possible for me to hook up a RCA home theater to it ?
  • David Dahwud Hughes Jul 05, 2010
    Thank you so much for this info. It was very helpful
    President:
  • 1,099 Answers
it is possible , you can use HDMI cable ofr the RCA cable
If you've recently bought a home theater system, you are undoubtedly anxious to set it up so you can enjoy your first movie. But setting up a home theater system is far more complicated than setting up a TV or stereo. The following tips will guide you through the setup, for optimal performance.
Step 1: Check Hardware
Examine the cable outlets at the back of your new P home theater system as well as those at the back of your HDTV. You will find many that look similar. Just match identical cable jacks and connect them with the correct cables.
Step 2: Optimising Clarity
Look for a HDMI (high definition multimedia interface) hook on the HDTV as well as on the home theater. On a home theater system, this would usually be labeled as either “HDMI” or “HDMI Output”. This provides the best picture clarity and is by far the best cable to use.
Step 3: Video Hook-Ups
If the HDMI hook is not available, then look for an S-video or a component video hook up. These video hook ups will give you quite nice picture quality. You can identify the S-video jack as the large, round one. In the home theater, it would normally be labeled as “S-Video” and will be located under a “Video Out” title. Component jacks will also be located under the “Video Out” label. These come in clusters of three and are coded red, blue and green.
Step 4: Jacks
Located at the back of the home theater as well as the back of the HDTV, should be a yellow RCA jack. This would be similar in size to the component video jacks. You might find that this RCA jack will be grouped with a white as well as a red jack on your television. In the home theater, this will, in all probability, be under the label “Video Out.” It would be along with an S-Video connection. This option should be the last choice when connecting up your television. While the picture would be clear, the sharpness is not as good as with some other video options.
Step 5: HDTV
You can also hook up the HDTV and your home theater system by means of the best cable option available. What you would need to do is, you would need to plug the cable into the “Out” jacks on your home theater system. On your television, plug the cable into the “In From Antenna” or the “In”
Hope this helpout.......
Posted on Jul 05, 2010
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
Systematic diagram for samsung syncmaster 403t
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Schematic diagrams to power regulator board to many popular TVs are given. Here I can't attach it, as all of it are in PDF format.
Jun 25, 2014 | Samsung SyncMaster 403T 40 in. LCD...
No signal on tv
Your Samsung has an Input Source button on the remote. If you are getting a "No Signal" message, you either have no cable, dish, antenna, or HDMI input to the television or have the wrong source selected. With the television turned on and/or a cable box, dish etc turned on, select all of your sources until a picture appears.
Jan 17, 2012 | Samsung 403T 40" LCD Monitor
Samsung 403T no power
1) Fuse is good?
2) You must have 5vdc stanby voltage the minute you plug the set into the wall, this is a must have before going further. Please look for that first, then report back what you find. Pictures and Sch will be a great help. See example of my pictures here: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | Samsung 403T 40" LCD Monitor
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Samsung 403T 40'' monitor has no power. (CK40PSNB)
FYI, I have found the real solution for this issue with Samsung 403T. It is a design flaw which leads to this problem after a while. Luckily, it can be easily corrected, but it requires medium soldering/electronics skills.
Anybody interested in how to fix it feel free to email me and I'll provide you with the solution. Please make sure that the symptoms of your monitor are exactly the same with the ones described above.
Mar 25, 2009 | Samsung 403T 40" LCD Monitor
How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Feb 27, 2009 | Coby 5.1 Channel Home Theater Speaker...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
