Question about Startrac Fitness Products Star Trac 3900 Treadmill Remanufactured
On transport my startrac treadmill got wet by rain. I let it dry out for a couple of days. Now everything work (the incline) except the tread will not circulate.
SOURCE: StarTrac Pro Treadmill startup error (ee error
Posted on Jul 05, 2010
  • 6 Answers
SOURCE: my c2200 treadmill will not reset or operate other
This is dinesh from AADHI FITNESS SERVICE CENTRE...
Search for the details in justdial india...
Can we come to ur place and check the machine... My contact no is 9986202487
Posted on Jul 29, 2010
2manyhobbies
  • 129 Answers
SOURCE: shuts down when in use.
This sounds like a static electricity problem.
First, check your outlet for a proper ground connection.
Be sure that the ground pin on the plug has not been removed.
Depending on the model, a number of machines came with connecting clips to ensure that the upper console was grounded. They were installed during the time of assembly between the frame and console. Check your manual assembly instructions to see if yours is one of these, and check to be sure they have been installed.
Posted on Dec 30, 2010
Testimonial: "Not only the grounding screw was loose but also the surge protector that the treadmill was plugged into had been damaged by the loose connection."
  • 1196 Answers
SOURCE: how do i reset ee error list init on startrac pro
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful.
Posted on Sep 22, 2011
ercupa190
  • 12223 Answers
SOURCE: Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
Posted on Apr 04, 2013
Having JUST bought a second hand T920 and tried it out after test trying it at the persons house the incline has now stuck! it is on an incline and after switching everything off etc i still cant get it...
I have a T920 treadmill and i used to use it. now i realised that the belt is getting rubbed and treads h started coming out so I loosened it and cut the treads that came out but now the belt is getting folded and I have been told by a sports shop that i need to replace the belt but the shop does not have one to sell. any dealer in India
Oct 28, 2013 | Horizon Fitness Tempo Fitness Treadmill...
Incline
Run the software calibration for easy diagnostic, and fix it.
God bless you
Jul 03, 2013 | Merit Fitness 725T Plus Treadmill
Apr 03, 2013 | Startrac Fitness Products Star Trac 4500...
STAR TRAC 3500 SERIES ERROR EL4
1) Run the software calibration for easy diagnose and troubleshooting and fix. it
2) tight very well all connectors, and clean
3) Adjust the REED switch, see the diagram , clean and tight the connector very well.
God bless you
Jun 19, 2012 | Startrac Fitness Products StarTrac 3500...
My treadmill will start and you can increase speed and incline but fan will not work and you can not decrease speed or incline. And I can not stop the treadmill. I have to emer. stop.
I'm not sure if this will help.
First I was unable to identiy your model. Star Trac makes 'S Series' treadmills and Pro Tread DC (5500 Pro S model) treadmills. Can you be more specific on your model?
Second. I have used Star Trac customer service in the past and they are the best. They are responsive, and knowledgeable, and will provide troubleshooting flowcharts to help you solve your problem. I highly recommend giving them a call.
Hope this helps,
Kurt
Jan 21, 2011 | Startrac Fitness Products Star Trac Pro S...
I have just been given a star trac treadmill, how ever i do not have a instrutions manual. Would you be able to help me please.
Thankyou for your reply, how ever, i have worked out how to use the incline on my treadmill myself.
Regards
Tezza
May 04, 2009 | Startrac Fitness Products Star Trac 3900...
Star Trac TR4500 Treadmill. Need help connecting the display
I recently took mine apart if you still need the exact details.
Jan 17, 2009 | Startrac Fitness Products Star Trac 4500...
Startrac Fitness Products Star Trac 3900 Treadmill Remanufactured Logo
224 people viewed this question
Top Startrac Fitness Products Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Techmotionusa.com
Techmotionusa.com
Sportsmith LLC
Sportsmith LLC
Are you a Startrac Fitness Products Exercise and Fitnes Expert? Answer questions, earn points and help others
