Question about Emerson MW8985W Microwave Oven
Mw8115ss works **** dosnt heat up the food
  • brmoody Apr 18, 2008
    microwave works but dont heat up food
    Genius:
  • Emerson Master
  • 1,689 Answers
The controler board may not be outputing to the relay or thyristor (depending on the device used) for the magnetron power supply, or the magnetron may have failed, or the high voltage supply may have failed. This is just to mention a few things that can cause the nature of the fault condition that your microwave oven has.
You will have to take the oven in for an estimate. You may find it cheaper to replace it if it is not under warranty.
Jerry G.
Posted on Apr 18, 2008
My microwave gets hot on the outside but dosnt heat any food in teh insdie. What can be wrong?
The magnetron is not working. Is it bad? Fuse any good? Power reaching tube?
Mar 07, 2016 | In Microwave Ovens
My emerson 899rd dosnt heat up food
It's probably a failed magnetron or loose connection at the "FA" terminal of the magnetron.
Nov 27, 2012 | Emerson Mw8999rd Microwave Oven
Hi, I have an Oster OMW1199 microwave that will not heat food. The light turns on and the timer works, but no heat.
I bought-the oster microwave and like others it did not last long before it stop heating. I took (careful precaution!!) and (unplugged the the unit!!) to view the fuse which of course is the main problem why this microwave does not heat up. Everything else works well but the heating. But since I changed the fuse to something very close to the same amp of the actual fuse it did work fine next to nothing.
I did not find any problem other than the noheating. This should only be attempted by someone who is in fact has close knowledge of electricity. The process is safe (WITH THE CORRECT PRECAUTION!!).Ever since I replaced the fuse and found out that that was all it needed I have been using it for 8 mths. Note--I did take measures into my own hands which is not recommended by anyone. But it is the old-fashion way...
Aug 28, 2011 | Emerson Fans Emerson MW8115SS Microwave...
It dosnt heat the food and makes a loud noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 16, 2011 | Kenmore 62702 Microwave Oven
Microwave stopped working during heating process....timier works but does not make that microwave sound
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 28, 2010 | Emerson Fans Emerson MW8115SS Microwave...
Everything fine but dosnt heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hgdgh
Jan 27, 2010 | LG Galaxy Countertop Microwave Oven
My Emerson MW8115SS microwave works but doesn't heat anything up, what could be wrong? And is it a easy fix?
Hi there.
Obviously it is "not working"
Could be an internal fuse or the activator is just finished.
Iceman.
Nov 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Model mw8115ss suffix a Emerson Microwave not working
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Aug 03, 2008 | Emerson Fans Emerson MW8115SS Microwave...
Emerson mw8115ss microwave
If you don't have your manual, you can download it here:
http://emersonradio.com/owners/MWO%20manual/MW8115SS.PDF
The manual will also have contact info for Emerson in case you want to check with them on this.
The magnetron may be going bad, and they usually have a warranty of several years on that.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Microwave Ovens
Emerson MW8985W Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
