Question about Ryobi ZRRY46501 Factory-Reconditioned 12 Amp 3.42 HP Electric Tiller Cultiv
PULL CORD START SYSTEM ON ENGINE SLIPS & DOES NOT ENGAGE CLUTCH
IT IS UNDER WARRANTY BUT I CAN NOT FIND A SERVICE CENTER OTHER THAN HOME DEPOT WHERE I BOUGHT IT.
  • 4 Answers
Take it to Home Depot and ask for a replacement if it was just purchased , otherwise just let them repair it.
brucewo
Posted on Jul 05, 2010
2000 Honda, VFR 800. Clutch began to slip when in gear, sometimes worse than others. One time clutch would not engage at all, had to tow. At home with engine cool, clutch worked fine. Clutch springs?
possibly
it indicates that the clutch is slipping from not being fully engaged, overheating and fading
check for the correct clearance at the cable end as the cable may be breaking internally and not allowing full engagement
Dec 23, 2016 | Honda Motorcycles
Hi, Daniel and the usual suspects are:
1. Clutch controls improperly adjusted.
2. Insufficient clutch spring tension.
3. Friction discs or steel discs are worn or warped
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Third Gear Clutch Slipping Wtf
Clutch Service Don Slip Cyclepedia
1998 2001 Honda VFR800FI Service Manual VFR800 Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
Honda VFR800 Owner Manual
Dec 23, 2016 | 2000 Honda VFR 800
Blockage in pump of huskey 2600psi
You may need to have the pump replaced. Most Husky pumps under 3000 psi don't have parts available. If you bought it within two years, the pump should still be under warranty. Check with Home Depot for service centers near you. They should be able to verify if it qualifies for a free replacement based on the serial number.
Feb 15, 2013 | Garden
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
Clutch not engaging
Does the clutch not engage( ie it slips & wont pull away) or does it not dis-engage (ie always in gear)
Was the clutch dismantled or disturbed when top-end was replaced
Is clutch hydraulic or not
Jan 31, 2012 | 2005 Suzuki RM 85
I have owned my Model 224L Trimmer less than 60 days, last night I tried to use it and the trimmer head would only engage occasionally. It would start to spin then disengage, even when I had all the right...
It sounds like a warranty issue, up at the engine you have a centrifugal clutch bolted to the flywheel, as the engine speeds up the clutch expands and engages with the drum, this in turn rotates ans turns a flexible shaft within the tube, this engages into the gear box and turns the gears that turns the head, so i would say the flexible shaft is either slipping in the drum, or the tube or gearbox has moved out board so is now too short to engage into the drum.
Jun 14, 2011 | Husqvarna Garden
Using a garden auger with the torque set to the highest setting the clutch broke and started to slip. Is this too much for the Dewalt 720 cordless drill? Dewalt is repairing it under warranty.
Yes, luckily Dewalt is taking care of you. You might want to look into a 1/2' drive electric model (sorry with a cord) Alot depends on how hard the ground is but in the long run the big electric will handle about anything you throw at it. Check Sears or Home Depot both good sources for good tools
Jan 04, 2011 | Dewalt 18 Volt Compact Drill Kit
I bought a makita tool set from Home Depot not even three months ago and i just tried to charge my batteries and the red and green light is coming on for both batteries. Is it possible both batteries went...
Hi David, there are 2 things you can do.
1) If you still have the reciept, I would take it back to Home Depot and attempt an exchange, assuming the tools look like they only have half an hour on them. That will be the quickest, if it works.
2) Follow the link below, type in your zip code and take it into your nearest Authorized Warranty Center. They will also require a receipt.
At this point it is irrelevant what is wrong with it if its under warranty. If it ends up not being under warranty for whatever reason, your assumptions are correct. It could very well be both batteries at the same time, or a faulty charger. Big box stores like Home Depot dont recycle stock the way they should. I went to a local Home Depot and found a DeWalt battery with a date code that was 4 years old.
http://www.makita.com/en-us/Modules/Service/ServiceCenters.aspx
I hope this helps, and good luck.
Nov 27, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Just had a Poulan 12.5 hp 38 in. mower delivered from Home Depot. Put in the gas and it started right up. Put it in gear, let out the clutch, it stalled. Left it in nuetral, let out the clutch, it stalled....
Sounds to me like the seat switch is defective,or the reverse switch on the trans-axle is out of adjustment or it is defective,unplugging it will confirm the problem.If unplugging ithe switch for the reverse pedal makes it work then that is the the switch you need to replace or adjust,if not ,replace the seat switch.
Apr 14, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Ryobi ZRRY46501 Factory-Reconditioned 12 Amp 3.42 HP Electric Tiller Cultiv Logo
131 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
