Question about Toshiba Computers & Internet
I can't get my laptop to turn on. My son was useing it the night before and it was working fine. He left it on the charger all night and when we tried to turn it on, it wouldn't come on. Any ideas?
  • jsja Jul 05, 2010
    Toshiba Satellite Model l355-s7905
    Still won't come on. worked fine before. My son used it, put it on charger all night, went to use it next day and it would not turn on. Battery charger is about one month old it is a replacement charger with no lights on it. PLEASE HELP I NEED THIS COMPUTER FOR MY JOB
  • jsja Jul 05, 2010
    please help asap if i need a new battery, i'll order one i just need to know if that's what my problem is.
  • Toshiba Master
  • 4,806 Answers
Try this simple solution first.
Remove the AC power cord, battery and any other external device from the laptop.
Hold down the power button for 30 seconds to dispel and residual power from the laptop motherboard.
Now just plug in the AC power only, leave the battery out and turn the laptop on.
If it boots up let it load the OS and then shut it down. Reinsert the battery and see if it will boot with the battery in.
If this does not help matters please post back giving a full description of what you can see/hear. For example any light indicators, strange noises etc.
Good luck.
Posted on Jul 05, 2010
  • 2 more comments
  • jsja Jul 05, 2010
    all that i can see or hear is the battery light on the front of the computer flashing on and off 6 times orange. it will not power on. i noticed what appears like a picture of a plug on the front of computer beside battery picture it doesn't light up at all does this mean anything?
    I hope to hear back from you soon. the others never replied back after their first suggestion
  • Lee Hodgson
    Lee Hodgson Jul 05, 2010
    Did you remove the battery and try boot the laptop on AC only? Also, you said to the previous experts that you had bought a new charger for the laptop? Was this a Universal charger which which comes with different connectors?
  • jsja Jul 05, 2010
    Yes, i tried it just like you said. It still won,t turn on at all. The charger i bought did not come with different ende. it is a replacement for a TOSHIBA SATELLITE l355-s7905. i ordered it off e-bay. could it be the problem. it worked fine up until now.
  • Lee Hodgson
    Chances are that you have bought a univeral charger from eBay which has possibly done the damage to the laptop. This is because you can only set the voltage on a universal and not the amperage. If the amperage is not correct then over time they damage internal components on the laptop motherboard.
    If your charger is an OEM (one that is meant for that laptop and supplied by Toshiba) then there is a possibility that there has been a power spike or surge during the night when it was charging. Have you noticed anthing odd with any other electrical items in your house? Like clocks reset etc?
    The flashing amber lights on the laptop is a code for what is wrong with it. I have looked for amber flashing lights 6 times for your particular model and have gotten no where although i'm pretty sure that its something to do with the power input not being sufficent or too much. Thus why i asked if your area was suffering from power spikes or surges. These can be caused by storms.
    You need to give Toshiba Customer Services a call now and explain to them your problem, describe the LED blinks to them and see what they say.
    They will however probably say that the problem is the laptop motherboard and it needs to be sent in for repair.
    If the laptop is still under warranty then they should carry out any repairs free of charge.
    I'm sorry i couldn't be of more help.
    Good luck.
    President:
  • 1,561 Answers
Remove the battery from the laptop and plug in the adapter to power supply and connect the adapter with your laptop, power on your laptop to see if it will power on, if it power on, unplug the adapter and put back the battery, try power it on while the adapter is still connected to power outlet, if it powers on, remove the adapter from your laptop and power on the laptop, if it did not power on, it means the battery as been short circuit and will need to be replace, follow the step one after the other to see where the problem lies, but i believe so much that the battery might be the problem, so remove the battery and plug in the adapter to your laptop and power outlet and turn on the laptop to see if it will turn on, if it does, replace the battery.
Take care.
  • 2 more comments
  • jsja Jul 05, 2010
    I tried this and it still will not turn on. I put the battery back in and tried to turn it on and all that happened was the battery light on the computer would flash on and off orange.
  • jsja Jul 05, 2010
    any new suggestions
  • jsja Jul 05, 2010
    are you still there?
  • Sulaimon Jimoh Olayemi Jul 05, 2010
    Look at the battery indicator light on your computer. Is it on? If so,
    check your brightness settings. If your laptop appears that it is not
    on, it may in actuality have lowered brightness settings. If the
    brightness setting is at its lowest setting, the laptop screen will be
    completely dark, and the laptop will appear to be powered off, even
    though it is not. Try cranking up the brightness settings.
    Check your AC power adapter. Is it snugly plugged into the wall or surge
    protector? Make sure the connection is made and it is not loose. Also,
    try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have
    had the same battery. Most modern batteries are only good for about
    1,000 full charges. After that point, the battery can and eventually
    will greatly deteriorate. Replace your battery if necessary.
    Replace your battery by powering off your laptop and then flipping it
    over and locating the battery cover outline, which will be near the
    bottom back of your laptop. Remove any screws with a Phillips
    screwdriver and pop off the battery cover. Slide out the old battery.
    Put in the new battery by sliding it in until it clicks, and then
    replace the cover.
    Consider replacing your laptop monitor. Your laptop may power on, but if
    the monitor display does not work, it will appear to be off and you
    will not be able to operate the machine. Check to see if your current
    LCD display works by plugging your laptop up to an external monitor
    using a VGA cable. If the external monitor displays your computer
    contents, your computer motherboard and underlying systems are still
    working, but your display will need to be replaced.
    Take care.
  • 560 Answers
Hi. Remove the charger, remove the battery then reinsert the charger and turn the laptop on.
Please let me know if you get any light indicator on your laptop, on, blinking or no light at all. Does your charger has a light indicator? If yes, is it solid green when the charger is plugged-in?
Let me know further.... Thanks.
  • 1 more comment
  • jsja Jul 05, 2010
    I did what you suggested and it still will not turn on. No, my charger does not have a light on it. It is a replacement charger I purchased less than one month ago. No previous problems before this.
  • jsja Jul 05, 2010
    any more suggestions?
  • Liza Halbrook
    Liza Halbrook Jul 05, 2010
    Please try these.
    -Remove the battery, press and hold power button for about 30secs then release. Repeat 5 times. Insert the battery and turn it on. Note: press and hold the button as you normally turn on a laptop, don't press too hard. You may damage your laptop and get a sore finger.
    -try to use a diff charger or use your charger on other laptops with same model and see if your charger is still good.
    -if you can't borrow a charger, get a volt-ohm-meter tester and test the output of your charger and see if the output voltage is correct.
    Good luck.
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
My acer sw5-012-10js laptop wouldn't turn on. I used my charger and it charges and I left it charged for two nights. It charges fine but the laptop wouldn't just turn on
try holding power button on for 15-20 seconds, if nothing, try holding both power button and up volume button on together for 15-20 seconds.
Apr 09, 2015 | Acer Computers & Internet
Won't turn on?
stop leaving it plugged in all night it will over charge ur battery if doin so
Sep 07, 2012 | HEWLETT-PACKARD Computers & Internet
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Toshiba laptop
open the back case and put away your cos cell for reset bios .
after 15 minutes refix cmos cell to its position .then try.
best of luck dear.
Nov 01, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
