Question about Inverter TB Woods Etrac AC Inverter
Control terminal strip descrption for tb woods e-trac ue-1
    Sniper:
  • 57 Answers
Manual for the X2C product line is here. Per Gary at Vacon (who acquired the TB Woods line of inverters) the terminal strips for all the X2C model inverters is the same.
Page 17 & 18 are the terminal strip diagrams for 0.5-5 HP inverters and 7.5-20 HP inverters respectively.
Control Terminal descriptions (from pages 19& 20) follow:
CM
Circuit common, isolated from ground.
MET1
Analog meter output 1. Provides a 0 to 10 VDC (1 mA maximum) signal proportional to output frequency, load, or current through setting of 71-METER (see page 64). May be calibrated while inverter is running by programming 70-MCAL (see page 63). Output impedance is 475ω.
MET2
Analog meter output 2. Provides a 0 to 20 mA or 4-20 mA signal proportional to output frequency, load, or current through setting of 79-MET2 (see page 67). May be calibrated while inverter is running by programming 78-MCAL2 (see page 66). Output impedance is 10ω.
VIN1
Analog speed input 1. Selectable through jumper J20 for 0-5 VDC, 0-10 VDC, or 0/4-20 mA DC. A 4 mA offset is programmed by 24-FSEL (see page 53). Speed Reference can be defined through 24-FSEL as VIN1, VIN1 + VIN2, or VIN1 - VIN2. Also, switching between VIN1 and
VIN2 is achieved with Auto/Manual function.
VIN2
Analog speed input 2. Selectable through jumper J20 for 0-5 VDC or 0-10 VDC. Speed Reference can be defined through 24-FSEL as VIN1, VIN1 + VIN2, or VIN1 - VIN2. Also, switching between VIN1 and VIN2 is achieved with Auto/Manual function.
REF 5.0 VDC reference voltage, 3 mA maximum load. Use only for a frequency control potentiometer (5 kω recommended). FWD Digital input for Forward operation. May be programmed for maintained (standard) or momentary contacts by 21-MODE (see page 52).
REV Digital input for Reverse operation. May be programmed for maintained (standard) or momentary contacts by 21-MODE (see page 52).
V+ Positive nominal 12 VDC voltage. Only for use with digital inputs and ST1 Digital Output (75ma max.) See connection diagrams on pages 28 through 32. NO other use is allowed. MOL Motor Overload relay input. May be configured to generate a fault on opening or closing. May also be configured to command a Coast-to-Stop on opening or closing. See page 66.
PS1, PS2, & PS3 Digital inputs normally used for preset speed selection. Jumper J20 selects pull-up or pulldown logic (see page 21). PS3 can be defined as a Run/Jog selector or Auto/Manual Switch
by 21-MODE (see page 52), or as the ART selector by 41-RSEL (see page 55), unless the PI Regulator is enabled and PS3 is used as an ON/OFF switch.
Eight preset speeds are available if all three inputs are used, while only four are available if PS3 is redefined via parameters 21-MODE or 41-RSEL, or when the PI Regulator is enabled and PS3 is used as an ON/OFF switch. See the following page for the speed references that
result from the input states of PS1, PS2, and PS3.
PS1 PS2 PS3 Effective Speed Reference
0 0 0 Basic speed setpoint (keypad or terminal)
1 0 0 33-F2
0 1 0 34-F3
1 1 0 35-F4
0 0 1 36-F5
1 0 1 37-F6
0 1 1 38-F7
1 1 1 32-FMAX
PS1, PS2 [1 - see note at bottom]
0 0 N/A Basic speed setpoint (keypad or terminals)
1 0 N/A 33-F2
0 1 N/A 34-F3
1 1 N/A 35-F4
ST1 Digital output (open transistor collector). May be set to activate under one of ten conditions. See 72-ST1 (page 65).
NO Normally open contact for the auxiliary relay. Will close when the relay is activated. Rating is 115 VAC at 1 A.
RCM
Auxiliary relay common terminal. Factory programmed as a Fault relay but may be set to activate under one of ten conditions. See 75-STR (page 65).
NC Normally closed contact for the auxiliary relay. Will open when the relay is activated. Rating is 115 VAC at 1 A.
Notes:
1. These settings will be utilized when PS3 is redefined via parameter 21-MODE or 41-RSEL, or when the PI Regulator is enabled and PS3 is used as an ON/OFF switch.
If you need more info, please reply back.
Posted on Jul 06, 2010
1 tb internal hard drive recognised as 300gb?
Please check it:
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. What is the information of your 1 TB hard drive? Is there any unallocated space?
Mar 02, 2014 | Western Digital WD My Passport Essential...
Tip
How to fix stripped screw holes in wood
Over time, screws in wood become loose, such as in a cabinet door, and no longer tighten. This is because the threads in the wood have stripped out. The solution is easy: Obtain toothpicks and wood glue. Coat a toothpick with glue, and insert into the stripped out hole. Keep inserting coated toothpicks until you have to use a hammer to lightly tap the last toothpick in. Allow the glue to dry overnight. After drying, cut the toothpicks off flush with the wood using a small knife. You now have a new area to re-insert the screw.
on Jun 17, 2010 | Home
I am missing the measuring beaker (part CEC-7BK) that is used with the Cuisinart Egg Cooker. They are no longer available in Canada and several US companies don't ship here. Any solutions welcomed.
Hard: 1 egg/8 TB; 3 eggs/7 TB; 5 eggs/6 3/4 TB; 7 eggs/6 1/2 TB. Medium: 1 egg/4TB; 3 eggs/3 3/4 TB; 5 eggs/2 3/4 TB; 7 eggs/2 1/2 TB. Soft: 1 egg/2 1/2 TB; 3 eggs/2 TB; 5 eggs/1 3/4 TB; 7 eggs/1 1/2 TB. Note:oddly, the amount of water goes down instead of up for more eggs.
Dec 02, 2011 | Cuisinart CEC-7BK Egg Cooker Beaker with...
We have a Bosch SHE45M06UC/50 in an island with a granite countertop. It is not attached and so moves. How do we attach it to the granite countertop? Or how do we attach it????
You glue on a wood strip, to the underside of the counter, then screw into that. Use construction adhesive. The wood strip needs to stick down no further than the counter edge treatment, so you normally cannot see this wood strip.
May 11, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Replacing the bottom comp wood with thin plywood.There's a strip of silver tape attached to the wood with a ground wire attached. What is that tape and where can I find it?
We have no idea what model instrument this is... maybe a piano??? The metal is undoubtedly for electrical shielding... nothing magic. Glue some aluminum foil with contact cement to your replacement wood. Using a screw and a terminal lug with a wood screw, attach the wire to the foil. One can also buy adhesive backed aluminum tape, but the width of that is limited to about 2 inches wide.
Apr 20, 2011 | Roland Music
Coming to a stop the truck will shudder and then cut off.. is this related to the throttle body? it was doing this before and the shop cleaned the TB
It's more likely to be related to the Idle Air Control Motor (IAC) than a dirty Throttle Body. Fords are known for sticking IACs - especially in cold weather. It is possible that cleaning the Throttle Body may have temporarily put a "Bandaid" on a sticking IAC.
Jan 24, 2011 | 2004 Ford Explorer Sport Trac
Trac off, trac vsc and check engine engine lights
Battery was diconnected for 1 minute and then reconnected. All lights are off.
Mar 24, 2010 | 2002 Toyota 4Runner
Need to know Amps & Volt. for Simpletech "Simple Drive" 1Tb.
The output of your adapter is 12volts 1.5amps the outside terminal is negative polarity and your connector looks like this (see below)
4927b50.jpgThere are two options of adapter (see below) both will work
EBAY Search for your adapter
Feb 13, 2010 | SimpleTech 1 TB 7200 RPM SimpleDrive USB...
I have a Goodman phk 024-1 unit that will not heat.
Basically, set unit to call for the heat strips to be energized. There should be a control that sends power to the heat strips. Usually a contactor or relay. Verify that power passes thru this device to the heat strips. Make sure that the correct voltage is being delivered to the heat strips. If correct voltage is present at the terminals of the heat strip, check the amps. If no amps, heat strip is probably broken. Don't forget that some of these units have sequencers that "Stage" the energizing of the strips. And all of them should have some safety device such as a fuse or thermal overload or some other device that stops voltage should there be a malfunction.
Hope this helps.
Feb 05, 2010 | Goodman PHKJ048-1 Air Conditioner
Is there only 1 computer for the 2000 olds intrigue? if not whick one controls the ABS and TRAC controls. The ABS , TRAC control, brake ans service engine soon lights are.
dont think its computer,but you have one for engine and another for abs/trac and then body computer, scan engine codes and go from there,hope this helps.
Oct 10, 2009 | 2000 Oldsmobile Intrigue
Inverter TB Woods Etrac AC Inverter Logo
211 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
