Question about Panasonic KX-TA308 Phone
Unable to dial 1800xxx or any other 1xxxx numbers
Hi
I have a Panasonic PBX KXTA616. I am able to dial 1800xxx (or any other external number that starts with 1) from the main phone (ext 1) but not from any other extention.
The main phone is Panasonic phone all others are regular phones.
  • Carl Navarro
    Carl Navarro Jul 06, 2010
    What do you get when you dial 9? Look at the main phone after you dial 9 and you may get your answer.
  • greish Jul 07, 2010
    I get CO 1 or CO 2. I am able to dial the 1xxxx from the main phone only (after getting outside line). Cannot dial 1xxxxx from any other extention (after getting outside line)
  • Panasonic Master
  • 2,460 Answers
The things that control restriction (TRS) is class of service and Allow/Deny codes, or it may be in the dialing restrictions of the station.
Your system administrator or manual will have specific instructions on how to program the system as it's beyond the scope of a free and public forum to tell you how it's done. Once you understand it, it's a pretty simple program. In the U.S., we actually screen up to 10 digits, allowing 1800,1888,1877 etc. and denying everything else. We don't have the TA-616, but we do have the TA-624/824. Programming gives you about 20-25 allow and deny tables. If you do score a manual, check out TRS.
Carl
Posted on Jul 08, 2010
Dear sir i have Panasonic KX-T7730 Phone but when i receive a call iam not able to see the caller's number on my LCD Screen .. what should i do to display the number on the screen . in my office i have 10...
First: you must activate Caller ID service from company that is supplied to the external phone lines
secondly: you must buy Caller ID cards for PBX
If these conditions are met Send me a message in order to explain to you how to install and programming this service
Jul 22, 2014 | Panasonic KX-T7730 Corded Phone
KX-Ta824 Speed dialing problem
Panisonictel.com has a FAQ for this model here
In that FAQ, there is this explanation of your problem:
When I tried to access speed dial, it does not call out.
When storing speed dial number of external parties, the stored speed dial number must include CO (outside line) access code (9 or 81…etc) even with direct line access. If the external number is 1234567, you must store the speed dial number as 91234567.
This rule applies to all system speed dial, station speed dial and speed dial key.
It looks like you're just going to have to add a leading 9 to all the speed dial numbers for that function to work.
Nov 04, 2007 | Panasonic KX-TA824PK Phone
I CAN'T SEND FAX WITH EXTENSION NUMBER
Generally if you wanted to send a fax to a facsimile which is connected to an extension.you must dial only the direct line number and ask operator to transfer this call to fax (wanted extension).After you heard the fax tone you can push start button.
If the fax machine full-time connected to same extension & dedicated direct-line there only for faxing,we can program the pbx for automatically transfer the incoming fax or call to that extension.so outsider have to dial only direct fax number without ext no.
Only Panasonic PBXes having a unique feature if i'm wright if it detect fax tone from any direct line it will automatically transfers towards fax extension.
Mar 24, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
Hi, i have a cuestion and i hope you can help me i cant receive faxes in my Lexmary x4270 is connected to PAP2 and configured codecs etc, and this PAP2 is connected at the same time to PBX asterisk,what...
Here are some guidelines on how to receive faxes behind a PBX system:
  • First, make sure your Lexmark X4270 printer can receive faxes when not connected to PAP2 and the PBX system.
  • Ensure that your printer/fax is connected to correct Phone port on your PAP2.
  • Advise the sender to dial your number so that there is a pause before dialing the extension number to your fax machine. They could insert commas between your fax number and the extension number. It inserts a delay of few seconds each. (e.g. 1234567890,,,,,,,,,,456)
Aug 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
Having trouble entering speed dials - please help!
Not knowing the specific model of the phone system itself (the PBX cabinet in the telephone closet) I would guess you are using the "personal directory" and it only has 10 number memory and it goes from 0-9. The system directory will give you more mems.
Sep 03, 2009 | Panasonic KX-T7730 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
Changing numbers?
To program the personal directory Its diferent to program the system directory. the personal has 8 number capaciti and the system has 999 number. To program the System directory
1.- Enter to PBX program mode from your station 101
2.- Choose program 001 to enter the quick dial numbers
3.- Choose program 002 to enter (Or change ) the Labels
Jul 05, 2008 | Panasonic KX-T7630 Corded Phone
Talkwitch 240VS and TS400 phone
To setup the phone to automatically insert your external dial group (usually '0') before numbers, so you can save them in your phone book, and make calls from your missed / received call logs, you should check the TS400 manual.
For the TS350i you do this 1) press transfer/menu button 2) Press 4 - Call preferences menu 3) Press 8 - Access Code Prefix 4) Enter the number you use for outgoing calls (usually 0) 5) Press OK
May 06, 2008 | TalkSwitch CT.TS001.124001.US...
Panasonic KX-TA308 Phone Logo
110 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
