Question about Refrigerators
Ice build up on the freezer floor then leaks out the door
  • 975 Answers
Thats the THERMOSTAT , is defective , this unit is connected underneath the freezer floor , when you remove it your gonna see like a black thick line running all around the freezer floor ,every 4 or 6 hours this line heats up avoiding ice to build up on your freezer. hope this info helps
Posted on Apr 18, 2008
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Ice buildup on floor of freezer
Is the fill tube for the ice maker dripping?
Nov 27, 2012 | KitchenAid KBFS25EWMS - Standard-Depth...
There is ice build-up on the floor of the freezer. If I don't chip it out, it will leak onto the floor in front of the freezer. Any suggestions?
check that the door seal is an air tight fit all around the door,,if hot moist air is getting into the freezer this is were your getting the ice from,,,also check that the thermostat is working if its not cutting out the freezer is working flat out full time,,thats a lot more ice build up
Jul 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is jamming on external dispenser. open the door and ice falls all over floor. what could it be?
my freezer is leaking water all over the floor it can come ok for a few days then starts again also build up of ice inside freezer any ideas how to solve this??
Sep 09, 2009 | LG Refrigerators
Ice build up on the bottom of freezer
Check to see if after clearing out the ice sheet, that the gasket for the door is tight against the freezer. If air is leaking by the gasket, it will build up really quick.
Jul 09, 2009 | Kenmore Refrigerators
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
