Question about Janome Sew Precise Mechanical Sewing Machine
Where can I order a zipper foot for the Brother VX1010?
  • 980 Answers
Direct from Brother or main agent
Posted on Jul 05, 2010
My daughter is studying costume design she has to provide her own zipper foot (L & R). If she doesn't have a model # for the Brother sewing machine will any Brother industrial foot work? Thanks!!
The Brother should have a model somewhere on the machine unless the label has been removed. There should be a label, perhaps on the back of the machine or near the electrical plug.
She can determine which type presser foot she needs:
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Or she can take a presser foot from her machine to a Brother dealer or sewing repair shop and they can tell her which foot will work.
Nov 24, 2016 | Brother Sewing Machines
I cant figure out how to put the bobbin carriage back together on my brother vx1010
I think you're talking about the shuttle and race. It goes together like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
Jan 21, 2014 | Brother Sewing Machines
Have brother sewing machine sc9500. Need invisible zipper foot. Don't know which kind to get.
My invisible zipper foot is a plastic generic one which was describd as being "low shank" and it works fine on three different Elnas I own.
I would have thought your machine was a low shank style too, there is a fair bit of similarity between feet with low shank clip on style. So if your feet clip on and off the shank, then you should be able to clip on another type of foot too.
if you try this link http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
then go through to the page for the foot attachment system that looks like yours you might be able to establish which one you need. THere is a brother high shank invisble foot listed, and an alternative part number. I jcan't see a Brother SC9500 machine listed so you might need to do a bit of elimination.
You could also email sewingpartsonline.com and ask them to help you identify the right foot.
Jul 12, 2011 | Brother Sewing Machines
Would you please advise how I put a zipper foot on my brother bm-3600, the needle will not align with the foot when I put the foot down! Thank you.
Did a google image search, this looks like a newish machine so I'd assume clip on feet?
Put the foot on the pressure plate, lower the foot on and align so it clicks into place.
Couldn't get an image of the foot but many zipper feet are designed to mount either left or right side of the foot so you can sew both edges of the zip in the same direction, ie pressure foot to left of the needle for one side, and to the right of the needle for the other side of the zip, you want to stitch in the same direction to avoid creeping.
Some machines you change the change the needle position to the left or right in order to get up close to the zipper foot.
Probably a manual would assist explaining this better, if you don't have one for the machine, I'd suggest that you obtain one.
Mar 07, 2011 | Sewing Machines
How do I attach the zipper foot? thanks!
Here is a website link that has picture illustrations of how to sew in a standard zipper, using both the centered and lapped methods, as well as how to insert the popular invisible zipper.
http://www.threadsmagazine.com/item/3728/sewing-in-a-zipper
Hope this helps.
Sep 15, 2009 | Brother Sewing Machines
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
On the Brother XL3750, how many presser feet does it come with? and what are their functions?
Go to www.brother.com and enter your machine type. Look for online pdf file for that machine. It should be able to tell you what it comes with, what they are and what they are used for. Most machines come with a button hole maker, a zipper foot as well as a dozen other types of feet. Mine came with a free hand embroider foot, zipper, button maker, and two others.
Try online manuals, since you can read them, store them on your hard drive for easy referral later.
Jan 08, 2009 | Brother XL3750 Mechanical Sewing Machine
Janome Sew Precise Mechanical Sewing Machine Logo
44 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
