Question about American DJ Crank II Mobile Trussing System for Stage Lights
How do the lights actually get hooked up to thew truss??? any close up pics of assembly???
    Champion:
  • 211 Answers
What size is Allen key for epiphone les paul standard pro truss rod
Frankly, if you are unsure how to adjust your truss rod, take it to your nearest guitar repairman. You can cause a lot of harm to your guitar if you do it wrong. Ask the repairman if you can watch what he does so perhaps you will be comfortable trying it yourself the next time.
Feb 12, 2014 | Epiphone Music
The neck of my guitar is not straight but i alreadyadjusted the trusrod
Edgar,
How are you determining that the neck is not straight? If you are thinking the neck is not straight because the strings are at different heights along the neck, the problem may be neck tilt or saddle and/or bridge height. You can raise or lower the bridge system or string saddles to add or subtract string height along the neck. In addition, neck tilt (particularly easy to adjust on bolt-on necks) refers to the angle that the guitar neck exits the neck pocket on the guitar body. This also effects string height.
Conversly, if you see a distict bow or bend in the neck when you look down the top edge of the neck, the truss rod may indeed be involved. Generally, most players like a little bit of "relief" in the neck. That is to say, a little bit of a concave bow. I prefer a relatively straight neck with very little relief. Just preference.
However, you mentioned you already adjusted the truss rod. Make sure the truss rod is functional. If you loosen the bolt or hex on the truss rod and the concave bow on the neck gets more pronounced, it is likely that you truss rod is ok. If you make adjustments on the bolt and there is little or no change on the neck relief, it is possible that your truss rod is not functioning or is broken. It is very possible to break a truss rod by over tightening but it would take some real effort to do. Still, it is possible.
Check out those points and see if it helps.
Confirm truss rod is working.
Check bridge height and saddle height.
See if adjusting neck tilt is possible on your model guitar.
Good luck.
Oct 17, 2013 | Fender Music
Tool to adjust truss rod
Any inbus the right size will do the job. Every respectable guitarshop should be able to tell you what that is for free. Don't even think of using anything even a little smaller: it will ruin the truss rod's head.
Feb 02, 2013 | Fender Squier Affinity Stratocaster...
Problem with truss rod on Epiphone SG Prophecy
i dont know your experiance level with this, but if it was me, i would take it to a professional, have them do it and explain to you how to do it.
Nov 23, 2012 | Music
Truss rods and dead frets- how do I adjust the guitar so the strings are close to the neck without getting dead frets?
I own an Epiphone Casino and if I needed to adjust the truss rod I would take it to a luthier (stinged instrument repair person). There is a good write up on it here. http://www.fretnotguitarrepair.com/trussrods.htm
Hope this helps.
Bob
Oct 31, 2009 | Epiphone Les Paul 100 Electric Guitar
Guitar truss rod dilemma
The truss rod must be too slack then.
Is the sound ok? Does it play ok?
In it's current state the truss rod is doing nothing.
If the guitar is sounding ok and playing ok, then the next time you change the strings pull the truss rod out and throw it in the garbage.lol
Seriously though...just pull it out and put it aside.
If,however,the guitar is not sounding ok then try tightening it.
If you're unsure about how much to tighten it then I suggest taking it to your local music store for help with that.
Sep 21, 2009 | Music
No the truss rod is usually in more than that. Take it to a reliable Musice Store and they shold be able to adjust it for you.
Sep 21, 2009 | Boss Micro BR Digital Recorder
String buzzing
Dont give up on the neck. One tec you saw may not know what another that has had many years in the repair of gtrs knows !. But for the time being you can fix this your self. Find a alan wrench that came with your Gtr.thats your ntail pice. This is the bridge that each string cross,s over. Now slowly rase up the height of the string untill its high enough to stop the buzzing. Just half turns at a time. . All so if you keep the humitdy up near your gtr. it may correct its self, no **** just like magic. keep on playing DFD
Apr 10, 2009 | Yamaha Electric Guitar
I need to know how to adjust my truss bar on my washburn d10 to make the string action bigger
Actually you can do this by adding shims under the saddle to raise the action. Then use the truss rod to make the action uniform if necessary. I try to avoid making adjustments to the neck because it could lead to undesirable perminent alteration to the neck. If you do make adjustments to the truss rod you should tune the guitar to pitch and let it sit left alone overnight to allow the wood time to adjust to the new adjustments.
Here is a link to an article on Adjusting action on an Acoustic Guitar.
Jan 24, 2009 | Washburn D10sbc Acoustic Guitar
American DJ Crank II Mobile Trussing System for Stage Lights Logo
Top American DJ Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an American DJ Music Expert? Answer questions, earn points and help others
