Question about Crosley 0187SST Turntable
My turntable worked for one side of a record. When I flipped the record over the turntable would not spin. What do I do?
    Guru:
  • 256 Answers
You will need to check if your belt snapped of simply slipped off due to wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Posted on Aug 18, 2010
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
I have a Spirit of St. Louis turntable that won't turn.
This model of turntable automatically stops when the needle reaches the center(the end) of the record. The motor should turn back on if you move the arm to the far right of the player, past its resting spot.
May 02, 2013 | RCA Spirit Of St. Louis Radio/Cassette/CD...
One side of my vinyl record will play fine but the other side won't spin right and the needle gets stuck on the record
The only thing you can do is clean the record with cleaning fluid. You will find special cleaning fluids for records on Amazon. If the record is warped you can try a weight pressing down on the record. But sadly if a record is warped bad there's no real cure.
Dec 28, 2012 | Crosley 0187SST Turntable
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
How do I adjust the auto return on a JVC A-21 record Player? The auto return keeps returning to the holder after the record finishes but then adjusts itself back twd the record and drops just on the edge...
Hi, this problem is caused by the cut off switch not depressing far enough to turn unit off. To remedy you need to do as follows.
1. Disconnect from power supply.
2. remove platter.
3. Flip unit over to expose the underside and remove all screws.
4. Remove base board.
5. Look at the gearing beneath the tonearm and identify switch that tonearm depresses at the rest point.
6. Loosen switch retaining screw and turn switch toward centre of turntable slightly until it clicks or closes. Tighten screw to hold switch firmly in place at that point.7. Reassemble and test.
Good luck. John. Styluscity@gmail.com.
Nov 01, 2011 | JVC AL A158BK Turntable
I just bought a Memorex Model 2655MMO turntable. The phonograph is fine when playing by itself. When I record a record to cd, the hum/vibration of the cd player turning comes back through the speakers and...
I know this question is old but I work on these specific units and have come across this same problem. What I have found out is there is a capacitor on the turntable motor that is there to reduce any noise that is caused by the motor itself. What I have done is wiggle the capacitor to see if the solder connections are intact. If the connection is loose the capacitor will not filter the noise and the noise is picked up in the CD burner and then recorded on the CD.
To get at the insides of the turntable you need to remove ALL the screws on the bottom of the unit then flip it back over. You will see a split where the front of the unit is attached to the base. Stick a flat headed screwdriver into the slot and twist gently to pop it apart. Then work your way all the way across the top of the front doing the same thing. Once it is free tip up the top half of the turntable to the left and prop it up. The capacitor is on the part you flipped up near the center of the turntable body attached to the motor that drives the turntable. It is a 104k capacitor. There is one on the tape deck motor as well.
Nov 26, 2010 | Audio Players & Recorders
PS-LX250H
Have you measured the stylus downforce. It usually is between 1 & 1.5 grams.
Apr 21, 2010 | Sony PS-LX250H Turntable
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Everything works on my record player but my turntable doesnt spin
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Sep 28, 2009 | Crosley 0187SST Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Crosley 0187SST Turntable Logo
217 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
