Question about Microwave Ovens
I just bought Magic Chef microwave ovenmodel#MCM770WTG last one in store no booklet or box. I desperately need an instruction book and this model is not listed on any of the Magic Chef websites. Can u help me get a downloadable manual?
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
  • 958 Answers
SOURCE: microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Posted on Feb 11, 2008
SOURCE: magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Posted on Sep 17, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Magic Chef Microwave Model MCO160S .
You can download that manual here.
Posted on Nov 27, 2008
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Posted on Mar 02, 2009
What causes vibration with the turntable?
It could be the turntable motor but you need to check for food debris under the 3 point stand that the platter rests on. Take the stand out of the oven and check the wheels etc, Magic Chef Microwave Turntable Motor 3966820810
Feb 09, 2017 | Microwave Ovens
What Type of fuse in the magic chef mcd1311st microwave?
It uses a 15A or 20A ceramic fuse 1/4'x1-1/4", which is available from home centers, hardware stores, home improvement stores, and big box stores like Wal-Mart.
See my help files:
http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm
http://www.microwavecontrol.com/doorsw.htm
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. (* on the tag in the cooking cavity or around the door frame or the control frame or on the back)
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 27, 2017 | Magic Chef Microwave Ovens
How to set the clock on a Magic Chef Microwave
Google the model number with "manual" or user manual or visit the Magic Chef site and search there--pretty sure if you call them they can either mail you the same or show you how to get it on their site.
Oct 14, 2012 | Microwave Ovens
Where can I get a light bulb and base for Magic Chef microwave model #MCP13E1ST?
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Just take the old one with you.
Dec 06, 2009 | Magic Chef MCD1311ST Microwave Oven
Nov 25, 2008 | Magic Chef Microwave Ovens
We need to know how to replace a magic chef microwave light bulb, please!
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Magic Chef Microwave Ovens
Microwave Ovens Logo
355 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
