Question about Waring WPM25 Popcorn Maker
Kettle does not heat up
We checked the plug and it seems wobbly.The blade does rotate but the kettle does not heat up.It's only six months old.
  • 8,404 Answers
Check the wires to the heating element inthe kettle.
Posted on Jul 05, 2010
The Kettle Agitator gets stuck. Appears the Rotating Center is Wobbly. . .
The motor output shaft bushing might have came loose I have seen where it falls out of the motor and the shaft becomes real wobbly and it will cause excessive wear in the kettle cross bar bushing too. also make sure the cross bar and lid assy. is not come loose from the kettle.
Feb 27, 2016 | Star Manufacturing Star G12-Y - Galaxy...
Kettle is not working. Totally shut off, no lights, no heat , nothing. Kettle only year old doesnt seem right to me that i am replacing a year old kettle. Appreciate you assistance. Mrs Nagy
Mrs Nagy, they do not make things like they use to, it is getting quite common for small appliance to break down after one year, you would almost swear it is built into them to garnade after warranty is up.
the most common problem, the electric cord itself breaks either at the plug or at the entry point at base of kettle, do a wiggle test on the wire to see if it makes a contact, just be careful of a shock hazard, do not do this if you see any bare wire at all.
press the helpful button,
Jan 21, 2016 | Oster 1.7 L Variable Temperature Electric...
Whirlpool duet washer error code f-02
Error F-02 is a slow drain problem. Remove lower front panel. You will see a circular door. Be prepared for a lot of water and junk, maybe keep some old towels ready. Open, clean out, check pump which comes right behind it - see that blades rotate freely; refit carefully. You are done, for the next six months or so, depending on usage.
Click if helped
Apr 14, 2013 | Whirlpool Washing Machines
F 20 ERROR Whirlpool 9kg Semi-Professional Washing Machine 3LCHW9100WQ
Click if helped
Apr 11, 2013 | Whirlpool Washing Machines
"On" switch blinks, kettle won't heat
In case you are still watching this issue for a solution - I'm afraid my assessment of the company troubleshooting support and of this particular issue is that we are out of luck.
I have the same problem. Have downloaded manuals - very little information except for use...ie, don't get them wet.
I have contacted the company - they asked me for the same information I gave them in the original troubleshooting request...
We bought a new one - fortunately on sale at Target. The blinking light is the normal indication - lack of heat and boiling is the problem.
Our new pot boils on both bases...old pot clicks and then just sits there with a blinking light - the light should blink until the temp is reached.
I intend to return the old pot to Target and move on....I suspect there is a burned out coil but, it is too hard to troubleshoot and won't be able to be fixed.
I suspect that a better (more expensive) pot might have more durable coils...but, we'll see how long the new one lasts.
Aug 29, 2012 | Oster 1.7 L Variable Temperature Electric...
Rotating arms getting clogged very frequently
I do not have a huge amount of information about the GE Profile PWD7880 handy, so I don't know if it has a chopper blade/food disposer at the bottom of your Dishwasher, but when a dishwasher gets the holes of the spray arm, the most common cause is the chopper blade is jammed/blocked. Then the food debris never gets sliced and diced at the end of the of each wash cycle.
Opening up the filter under the spray arm, removing as much of the lower assembly and inspecting every where in the sump area, especially the drain pump area would be a great beginning.
Good Luck! Just ask if you have more questions.
Apr 04, 2009 | GE 24 in. Profile PDW7800 Built-in...
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Mower shakes
sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Oct 13, 2008 | Poulan "Poulan" Push Mower
Whistling noise
Sounds as if it needs descaling. Do you live in a hard water area?
Aug 09, 2008 | Cuisinart CJK-17BC Cordless Electric...
Waring WPM25 Popcorn Maker Logo
375 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Colin Stickland
Colin Stickland
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
