Ge window ac making a noise after it is on for a while. a sort of soft screeching noise. what could it be
    Novelist:
    Champion:
  • 246 Answers
More than likely it's the fan motor's bearings running dry.
For the past several years the mfc's have been installing 'oil-less' motors in most window units (in order to sell more units/motors of course) - but there's always a chance your motor can be oiled, so I would check it out and see if there's a place to put oil in - sometimes there will be a plastic stopper in the hole (on the motor) and all you have to do is pull it out and add oil. Note: look for a place on both sides of the motor to oil.
If by chance you don't have a place to oil the motor, you can always try drilling a hole on top of the bearing(s) - (which I've done with moderate success in the past) and then squirt oil in the hole you drilled.
All of this is assuming it is your fan motor (most likely cause) - but there could always be something else, as in the compressor bearings - in which case you can't do anything about - but I would bet it's the fan motor.
hope this helps
Posted on Jul 05, 2010
Testimonial: "Thank you very much! But my husband gave up and went and bought me a new one. :o)"
Ge monogram zfsb23d howls
Usually you will get a sort of whinning/screeching noise from the fans inside the fridge/frezzer when they are not working properly but you can also get that howling noise from the fan which cools the compressor for the fridge/frezzer which is usually found underneath the Unit. All you have to do is find exactly where the noise is coming from and remember unless you have a dog that likes to lock itself in the fridge for a joke then most noises that come from fridge/frezzers are only made from the moving mechanical parts and sometimes leaking refridgerants but not often.
Apr 03, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Car Makes Screeching Noise When Turned On With Ac On
This is very typical of a slipping A/C compressor drive belt. Inspect the belt for fraying and cracking and renew it if needed. Check the tension and make sure it is correct, and in a new one recheck after about 4 wks. It should deflect about 1 cm in the middle of the longest span with a firm push.
You can put some soap or drylube wax on the contact surfaces of the belt but that is temporary. Do not use petroleum products like WD40.
Jun 19, 2017 | Dodge Cars & Trucks
My GE Model# DBXR463EB0WW makes screeches and
Open the door and there are some screws holding the top on. Then you remove the front after removing a screw on each side. But first UNPLUG it and remove a cover on the lower back to get the belt off the tensioner.
Feb 13, 2010 | GE Dryers
My serpintine belt started making a loud screeching noise, and eventually slipped off. I got it put back on but its still making a screeching noise. All of this started after i got the AC compressor fixed....
One of the belt pulleys likely has a bad bearing. watch the pulleys for binding while it's running or remove the belt and check each pulley by hand. AC puts more strain on the belt...if the belt is not new and pulleys check out, (and tensioner is working properly) change the belt.
Jun 07, 2009 | 1997 Pontiac Bonneville
Dryer screeching noise GE - DVLR223ET1WW
Remove the back panel and check the brake to make sure that it is not staying locked to the drum.
Jun 01, 2009 | GE DVLR223 Dryers
Spacesaver 1800XL Screeching or Grinding Noise
Is it possible that some spray cleaner got into the controls?
I always recommend that users spray cleaner on a soft cloth then wipe the control panel.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over itme, it may need to be manually dried or blown out.
But the keypad or control unit may be damaged.
Please post back with more details so we can help further.
Oct 18, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
