Question about Sony VAIO VGN-FS920 Notebook
I t seems that there is something wrong with the keyboard connection, it makaes a noise and it freezes, but when i disconnect the keyboard it works ok
  • 3 Answers
Its broken ad can't be fixed you need a new one exactsame thing happend to me
Posted on Jul 05, 2010
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
As I remember it, the EX 100 was plug and play on my XP PC. The batteries are NOT a problem - as they check OK. I periodically have both mouse and keyboard FREEZE After restarting XP computer everything...
Connect an additional wired keyboard to your pc. And when the freeze happens check if the pc responds at all, using the wired keyboard. If its not responding , its an indication of a faulty PSU or motherboard.
Mar 08, 2011 | Logitech Cordless EX 100 Mouse
There does not seem to be a caps lock indicator on my keybaord...hp-0851
There isn't one, the caps on indicator is supposed to show up on the screen. (IN THE TASKBAR)
Jan 08, 2011 | Computers & Internet
My keyboard says it is out of batteries after only 1 week. I have tried putting brand new batteries in and the same thing happened - this time, they only lasted 3 days! During this time the keyboard lost...
There is something definitely wrong with your keyboard. My batteries last 4-6 months or more.Even with real cheap junk batteries and a lot of use the batteries would last a month or more.
The first and about only thing you can check for and fix is a stuck key. If the key is stuck down the keyboard uses far more power (about 20x) as it is transmitting. That is about the only thing I can think of that will drain the battery that fast. The problem is it sounds like is actually working normally when its working. The disconnecting is going to be either internal or the antenna placement. With it connecting and disconnecting it would use more power but not that much.
I would check for stuck keys, but after that I'm afraid a replacement keyboard. There just isn't that much to fix inside or out of these things so you have very few options on what to do. If you have warranty get it exchanged asap.
Sep 03, 2010 | Apple Wireless Keyboard
Computer Freezes unless pressure applied
With the laptop turned off, take out the hard drive completely from the laptop and then reseat it back into its slot and make sure its nice and snug.
Then go ahead and turn it on and see it will run without freezing on you and having to apply pressure on the keyboard.
If that doesn't work then disconnect the keyboard and see if it will run smoothly without the keyboard. If it does then you might have a stuck key on the keyboard that is making the unit freeze so you might have to replace the keyboard.
Jul 06, 2009 | IBM ThinkPad T43 Notebook
Touchpad & Keyboard unresponsive
please replaced the laptop ,other option u r put the button & clean the button
Mar 16, 2009 | Acer Aspire 5720 Notebook
Gateway cordless KR-0401 Keyboard
I had the same problem. I solved it by pressing the connect button on the back of the keyboard and then pressing the connect button on the wireless connection base. The keyboard and the base will sync up again. Should solve your problem.
Jul 19, 2008 | Gateway 2520915 Keyboard
It doesnt work...
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Apr 09, 2008 | Razer DeathAdder RZ01-00150100-R2M1
Keyboarb
hi, its a very common issue, the keyboard itself needs to be taken care off,try removing it and clean the contacts/connectors, check if any key is getting stuck? let me know
Dec 03, 2007 | Panasonic Toughbook 51 Notebook
Fujitsu laptop 6240
You can connect an external keyboard and see if the problem persists. That would rule out a keyboard problem. Also connect an external mouse to see if the system is frozen or the keyboard/mouse combo are just not working. If its a keyboard problem, chances are you either spilled something on it or the connector came loose from vibration or general use. Unscrew the keyboard and reseat the cable. See if the problem is resolved.
Aug 17, 2007 | Fujitsu (G281065802)
Sony VAIO VGN-FS920 Notebook Logo
63 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
