Question about Dell Dimension 4600 PC Desktop
Have a Dell Dimension 4600 series computer. I have made numerous attempts to connect to the internet however shows "network cable unplugged" Checked cable for connection-connected. I did disconnect and reconnectyed the cable. Same message appears. I go to repair and a window appears and states "failed to query tcp/ip settings. Isp person came to the house today checked it out and said that I probably need to replace the ethernet card as the incoming service the the computer is ok. exactly which ethernet card do I need for this computer as I'am not at all familar with ethernet cards?
  • 29 Answers
There is many options available to you depending on how much money you would like to spent for basic internet the cheap one in the link will do. The main focus here is not the name brand but the slot type "PCI". There is USB`s available but it sounds like it will cause you more headaches than it would be worth. Have a great day.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=534927&CatId=200
Posted on Jul 05, 2010
  • 2,841 Answers
Check the cable by trying another one if you have not already done so. Before you buy a new ethernet card try downloading the driver for the ethernet card you now have and see if that solves the problem. Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_P4_4600 If not then any Ethernet 10/100 PCI card should work fine in your Dell.
I can't reset a 169 series IP address on my 4600C in order to direct connect to a cable modem (and internet).
Provided there is no hardware problems, this issue is fairly easy to resolve.
  1. Completely shutdown the system
  2. Unplug power to the cable modem.
  3. Wait 3 minutes (This allows the temp memory of the cable modem to scrub)
  4. power on the cable modem, let it reset (Takes about a minute)
  5. boot the system.
Normally this will force the cable modem to renew the MAC address of the device connected and give you a valid IP address.
If you still have an APIPA address, try right clicking the local area connection ICON and click REPAIR
If still no connection, reboot computer in safe mode w/networking and try again. If you get a connection then the issue is software (Firewall, Virus, Malware)
If you still are not getting a valid IP address, check your cabling and connection (Replace cable with a known good one if available) or try a different network card.
Jan 08, 2011 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 wi-fi shows good signal and it says it's connected to internet but in status it does not show activity so I am unable to got into internet.
Is your internet working on other computers in the house? Try reseting your router, if you need info on that let me know.
Oct 22, 2009 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 which is having intermitent problems connecting to the internet via a hardwire connection to a verizon fios wireless router. The router works fine with my dell laptop both when...
I assumed you adapted the pc with a device for wireless connection ..if all the other are OK ..the problem is this device ......try it on other computer ..if it works ..its just a compatibility issue ..if not its a problem with it ...
also try to change the freqvency they work in ..if it possible ....or change the position ..cause they work on a radio wave and you might interfere with something when it goes out of signal ...
Jun 16, 2009 | Dell Dimension 4600 PC Desktop
Ethernet on DELL 4550 with TP-link doesn't work
pinging 127.0.0.1 just tells you that your network card is operational and reacheable by your system.
I have a couple of suggestions - check them out and let me know what you found out.
  • Go to Network Connections / Local Area Connection / General Tab / Properties / Internet Protocol (TCPIP) (from the list)/ Properties. Are all settings set to "Obtain automatacally..."?
  • Is your operating system Windows XP Home or Professional (with Service Pack 2 installed)?
  • Have you installed the AirPort Utility software that came on the CD? (Check Start > All Programs > AirPort)
  • You have to have the software installed in order to setup the router.
  • What is your internet connection: Cable or DSL?
  • Take a look at this document "Designing AirPort Networks" which is also on the CD that came with the device. If you don't have it, here is the download (link). Go to page 25 and follow the instructions for PPPoE (if you have DSL service) or DHCP (if you have cable service).
Let me know how that works for you and if you have any more questions, just come back here and leave a comment - I'm happy to look further into that if this did not work for you.
May 27, 2009 | Dell Dimension 4600 PC Desktop
Can not get internet connections
First try to reboot your router ... just unplug it for about 30 seconds and plug it back in. See if your router shows back up (assuming you are wireless) or if connected via a CAT5 cable your internet connection gets restored.
If that does not work ... sometimes its helpful to reboot your DSL/Cable modem. First unplug the router, then unplug the modem, after the modem come back up, plug the router in.
Hope these steps help.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Adding Dell Dimension 4600 to existing wireless network?...
Go to Staples and purchase a Linksys USB wireless-G (only G needed - the new "N" protocol is overkill) adapter (~$60.00). Insert the Linksys CD and follow the instructions. When prompted, plug the USB adapter into the Dell (frt or back) doesn't matter. If his "roomies" have security enabled on their router, you'll need to know the level, password/passphrase, and the network name that they assigned.
Good luck.
gurutim
Mar 21, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension won't translate site names into numerical address
Maybe u aint both in same workgroup to use it change both the workgroup to same name (workgroup) then use the my network places under there view my workgroup computers and u can find the computers
Dec 25, 2008 | Dell Dimension 2350 PC Desktop
NETWORK ADAPTER
Reinstall the network adapter from the dell driver cd and reboot the system with the nic pluged in.
Jul 21, 2008 | Dell Dimension 4600 PC Desktop
Driver problems
JPWatson, This link will take you to the drivers for your Dimension 4600 with Windows XP: http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=DIM_P4_4600&os=WW1&osl=EN As far as the PC showing you already have a connection I would ignore that for now. Just download the appropriate drivers from this Dell page including the network interface card drivers and install them first. After you have rebooted and verified that the hardware devices are working correctly then start troubleshooting your Internet connection if it is still necessary. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 21, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
