Question about RCA HD52W59 HDTV Projection Television
TV doesn't come on.
When you cut the tv on the green lite comes on and then I here a frying sound and then the green lite goes off.
    President:
  • 1,099 Answers
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage. if otherwise the Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
Posted on Jul 05, 2010
  • jbtrloghomes Jul 06, 2010
    I took the tv apart to check for your soloution. I found a loose joint sparking. I soldered it back and the tv works fine now. Dan.
Will not stay on
It sounds like it could be your power supply board. You can get one from tristatemodule or shopjimmy. I personally use tristate its always cheaper and Ive had good luck with them but shopjimmy is pretty good too.
May 13, 2013 | RCA D52W23 52" HDTV CRT TV
32" emerson tv
I would suspect the power supply first Most likely bad capacitors. The main board would be suspect next as the power on command comes from the main board which switches on the run supplies.
Oct 29, 2012 | Emerson Lc320em1f TV
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Screen and sound problem?
sony 2005 kdf e60a20 tv---turns on and off every 2-3mins...green power lite stays on no blinking
Mar 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
WHEN I TURN ON THE POWER THE THE RED LITE COMES ON
We have a TV that does this after we have left it off but plugged in for awhile when we go on a trip. Just unplug the TV, wait a few seconds and plug it back in. If it's like ours, you'll find that resets it.
Nov 19, 2009 | Loewe ARC332 32" TV
Tv screen and sound are lost for about 10 seconds.
Can you give me the model number? If this is a projection monitor, it sounds like the ballast for the lamp is dying. Not fatal, but probably in the range of $200 to fix at the local service depot.
Jan 04, 2009 | Hitachi Televison & Video
Tv will not turn on. green lite for 4 secs, 3 times, then off. D52W20
It could be several issues from a bag power supply, the TV is connected to a power strip with several other components hooked up (DVD, Sound System, Xbox, etc.).
Try connecting to the wall directly and see if it now starts up.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HD52W19 TV
have the same problem, some kinda coolant leaks and fries the drive I was told...
May 30, 2008 | RCA HD52W58 52" TV
RCA HD52W59 HDTV Projection Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
