Question about Sansui VRDVD5000 DVD Recorder/VCR
My dvd player is ask for regional code? - Sansui VRDVD5000 DVD Recorder/VCR
  • 10,421 Answers
How do I get the code for my Koss dvd player to make it a multi-region dvd player
can you go into the settings menu and see if the region code is accessible?
Feb 17, 2015 | Koss KS4110 DVD Player
How do i set up free region codes for my Toshiba SD-38VB dvd player? Thank you.
Hello
Press the eject button on your Toshiba DVD and insert the foreign disc. A window will pop up informing you that your DVD is a different region and ask you if you would like to convert to this region.
Click "Yes" when you are prompted to change the region. You will only have a certain number of opportunities to change your region. On the last try, your DVD will only play DVDs from the designated region.
Find out the Toshiba model number and use this to research a code that will break the region code assigned to your player. Each player make and model possesses a unique code to break the region code, so make sure you are using the correct one and follow it exactly as it is written.
Sep 15, 2011 | Toshiba SD38VB Player
Region2 dvd titles play main movie nothing
it seems to me that your dvd player is not region free. it will play only region 2 dvds. to get the region free code u need to ask the dealer where u have purchased the dvd player. some dvd players do not have option to change region or to be region free.
Sep 13, 2011 | Philips Televison & Video
I have bought Pioneer DVD player 420V few days ago, but when I put disc I got message on the TV that DVD can not play because the region code is not recognized. Should I reset all systems or???. I need...
the region code means the player does not support the disc your playing each country is given a region code for dvd australias is region 4 if you buy a dvd from another country it wont work you can get multi region codes for dvd players im not sure of pioneers code but try using a dvd from your country region and youl find it works just fine you can also try asking a tech on fixya for the multi region code for the model dvd player you have.
best of luck
merry christmas
Dec 22, 2010 | Pioneer DV-490V-K DVD Player
What does check regional code mean?
It means your DVD player has a different region code to the disc you are attemting to play.
DVD's and most DVD players have a region code corresponding to the country/region in which they were purchased. The region code printed on the disc must match the region code of the player, usualy found on the rear of the unit or in the manual. Only players set to code 0 or 9 are able to play all regions, a setting of 1- 6 is most common. 1 = USA 2 = Europe etc.
It is often possible to set your player to code 0 or 9 enabeling you view all region DVD's.
May 16, 2010 | LGDVB418 DVD Player
I have a region 2 samsung dvd player. All of a sudden the following message displays: '' Can not play disk. Wrong region code'' We have been playing the dvd for more than 1 year. What is the problem? Same...
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Jul 03, 2009 | Samsung DVD-P181 DivX DVD Player
Region code
Type in region codes for DVD players in google
Jan 17, 2009 | Philips DVP3040 DVD Player
Phillips dvp1013
Hello Canada416,
Check the following link to the regional code data base for codes you can enter through the handset to unlock region codes. Let me know if this helps you or you need further assistance.
Jun 30, 2008 | Philips DCP855/37 Portable DVD Player
I would like to know this dvd player can play in europe
I couldn't find any info on this players region code, but most DVD stores carry DVDs from all regions, and many players today can play DVDs of any region. To be sure call the local DVD store that you like and ask them what region DVDs they have. Hope I helped ;]
Mar 30, 2006 | Pyle PLTV65R Car Video Player
Sansui VRDVD5000 DVD Recorder/VCR Logo
21 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
