Question about AEG B3101-4 Electric Single Oven
Hi there My AEG 8160D cooker hood has stopped working. The fan won't come on and the light won't come on. What can I check or replece.? Quick response much appreciated
2 Suggested Answers
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
No power to cooker hood
Should be on a separate breaker, sometimes wired to a clock/fridge circuit. Check all breakers. I have seen people wire them to a GFCI outlet as well, not supposed to, but people still do it. Check for 120Vac at the fan and light switches, if its ther your switch is bad, it not there cicuit is not connected to power supply.
Aug 25, 2014 | Ovens
Can't get the bottom oven working on my Zenith 50 cooker
Is it electric oven? Element gone most likely cause. Does the light and fan still come on?
Sep 05, 2012 | AEG Ovens
Hi I need the operating instructions for an aeg cooker pnc 944 185 047. ive set the time but I cant work out the timeing settings it keeps switching off after about 20 mins and turns its self back on...
hi you can get instructions fron serviceforce.co.uk . follow the instruction link and enter pnc no. however i think your problem is a controling stat for the cooling fan if the fan does not switch on the oven overheats the cabinet and switches off like you describe. its located in the wiring loom behind the control panel. the part is 899661927356-9 costs circa £26. hope this helps
Nov 21, 2010 | Ovens
Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
May 25, 2010 | Ovens
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
Fan comes on in the oven but the oven does not heat up, not sure if I have messed with the timer
Hi.
If the fan is working o/k, then there is nothing wrong with the timer, you need to replace the fan oven element, this will solve your prob.
Please rate my solution.
Thanks.
Sep 05, 2009 | AEG B3101-4 Electric Single Oven
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Nov 19, 2008 | Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
AEG B3101-4 Electric Single Oven Logo
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
