Question about Garden
Have a mountfield honda GCV135, need to change oil but cant find the plug? and want to know about air filter cleaning?
  • 3,740 Answers
Here is the manual.... : http://www.smallenginewarehouse.com/images/manuals/GCV135-160.pdf
On page 28 of the pdf file it says you have to shut off the fuel and then remove the oil filler cap/dipstick and then tip the engine to drain the oil.
Air filter cleaning procedures are on page 31 of the pdf file.
Thanks for using FixYa.
Kelly
Posted on Jul 05, 2010
Problems & Solutions for Mountfield 725m
Remove clean or replace spark plug. Remove clean or replace air filter. Ensure oil is full. 30w. Drain gas tank fill with fresh gas with Stabile. Gas over 30 days old no good! Try to start. No start clean or replace carb.
Jul 12, 2013 | Garden
Mountfield Mower is chugging.
Excess air. Remove clean or replace air filter.
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
What does a major tune up for a 2004 chevy impala consist of? What should be done and needs to be done?
New spark plugs, oil and oil filter, transmission flush and fill, fuel filter, air filter, coolant flush and fill, clean throttle body plate and bore, clean the MAF sensor, replace any loose or cracked vacuum lines, PCV valve, new air filter, new battery.
99% of the time all you should ever need for a tune up is new spark plugs, and a clean air filter and throttle body. But since your inquiry indicated "major" I gave it more critical thought.
Feb 18, 2011 | Chevrolet Impala Cars & Trucks
How to tune up a 155 Honda motorcycle
clean the filter element, located at the air box. check the carburators for dirts and foreign object... clean if necesary... go buy a carburator cleaner... replace fuel filter and spark plug... position the crankshaft to tdc... remove the 2 tappet cap cover... check the valve clearance, adjust if neccesary 0.05 - 0.06
change/replace the engine oil.....
Dec 26, 2010 | Honda NF 100 Wave Motorcycles
Honda passport 1994 4wh drive cant pass smog test. i change the catalytic converter, change the egr valve, 02 head sensor and major tune up, spark plugs, wires are all change still cant pass smog. i passed...
Here are a few things to look at:
Have you replaced the air filter? Have a compression test done on the engine, could possibly be a leaking vale. If any vacuum hoses have been removed from the engine they will have to be re-installed. Solid Lifters out of adjustment can cause incomplete combustion. Make sure engine is reaching proper operating temperature (eg. thermostat). Do not use low grade (octane) fuel for test.
Clean oil, tire pressure, brake drag?, every little thing counts.
Oct 12, 2010 | Honda Passport Cars & Trucks
I need to know to change my oil on my honda shadow aero. I would also like to know the best oil to use, how much oil and in general a brief description of the process, thanks! (this is so i dont have to...
You will need an oil filter (Fram,Honda, Emgo) an oil filter wrench (Honda or K&L) an aluminum oil drain plug washer, and any oil that has the JASO MA motorcycle oil rating. 10w-40 for cold climates and 20w-50 for warm climates and touring. Do not use any oil that says Energy Conserving on the label it will shorten the life of your wet clutch and transmission gears. Center stand the bike, use the wrench to unscrew the filter and place it in the pan. Wet the lip of the new filter with used oil and screw onto the engine. Be careful not to over tighten ( you will regret it next oil change). Place the pan under the drain plug and remove using a six point socket. Inspect the aluminum washer if it looks like a normal washer re use it. If it is deformed replace it.Put the drain plug back in with the sealing washer and snug it up tight. Do not over tighten , it only needs to seal the oil in not hold a cylinder head on. Grab a funnel and take out the fill hole plug , usually the dip stick on a Honda and pour in 3.5 quarts of oil. Put the plug back in , start, and run the motor to fill the oil filter. Now check the oil level and top up as needed you should not need more than 4 quarts total. If you want the bike to run cooler and shift easier you can use synthetic oil ( costs more ).
Sep 21, 2010 | 1999 Honda VT 1100 C3 Shadow Aero
2003 honda shadow spirit vt750 carb problem
buddy dont worry about it what you have done is put to much oil inside the engine and as the piston goes down it cause abit off pressure which in the small space it has when you over filled it the pressure inside has just forced the oil out the breather into the air box just give it a little clean and drop oil aswell bud
Sep 04, 2009 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
I have a 95 honda accord sputers at stop
getting oil on my plugs on 97 honda accord any help or suggest
Mar 17, 2009 | 1995 Honda Accord
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Garden Logo
688 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
