With these steps you can increase the speed of your BSNL broadband<br /><br />1 First of all make sure you are logged in as Administrator.<br /><br />2 Go to Start >> Run >> gpedit.msc , Press OK.<br /><br />3 Then go to Computer Configuration >> Administrative Templates >> Network>> QOS packet Scheduler.<br /><br />4 On the right it will give you the option of Limit Reservable bandwidth, open<br />and and select Enabled, and change the value from 20 to O.
U probalby is using windows XP or something like that wich can only format ur pendrive as "FAT" file system wich have max 4GB capacity per file, in order to fix your problem you need an external software for formating ur pendrive or use win 7 if you have win 7 just backup your data and format the pendriver and where it says " File system" will come with "FAT" as standard just click and select "NTFS" format it and be happy^^
download this file unetbootin-windows-471.exe, then you must have an ISO file of your windows xp, you can install ultraiso or any iso maker available on the web, insert your xp cd then make an iso image out of your xp cd... after having iso file for win xp, insert your pen drive (at least you have 1gig free space on your pen drive) then open unetbootin-windows-471.exe, under the disk image, locate your win xp iso file using the select disk image file button,. then just chose Usb Drive , and also on the drive chose the drive of the usb (check it on my computer and check the drive letter of your pen drive) then click ok... once successful transfer of image to the pen drive, restart pc then make your pen drive to be the 1st boot device
There is a program you can download to achive this and I do not have a directly link but i'll give you some pointers and that would to put the keyword "bootable flash drive" in the search field of google or yahoo.com, Please rate accordenly.. Sorry I do not have a direct link.
This can happens when Automatic Updates Feature is Turn On. Your antivirus definitions updations. By using peer to peer softwares like bitcomet, bittorrent, Bitlord etc., These can work in bacground and downloads the updates and softwares and shares the resources of the downloads. By these the limit can exceed.
To reduce these risk factors
Change 250 Plan to 500 limited plan or 750 Home unlimited.
If not disable the autoupdates feature.
1. Windows Xp installation disk 2. Access to PC with working CD Cd-ROM DVD drive. 3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software Let's start.
1. Download solution.rar file 2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos 3. Put your pendrive ( at least 1GB) into working PC USB port 4. Go to the folder C:\Dos and run HpUSBformat.exe file - it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: ) - set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it. 5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones) - your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
