Question about Panasonic Computers & Internet
I have not the sound driver of CF-29 so Can you tell me what is the name of driver CF-29
5 Suggested Answers
  • 37 Answers
SOURCE: pls tell me my sound driver name
Your sound driver is this one "Realtek* ALC861". It can be downloaded from here.... http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Posted on Sep 23, 2008
  • 3 Answers
SOURCE: no audio output device installed
best website I found for the Toughbook:
http://pc-dl.panasonic.co.jp/cgi-bin/itn/toughbook/dl01.cgi
Posted on Feb 09, 2010
  • 2291 Answers
SOURCE: I have no sound from my Toughbook CF-29. I have
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Oct 06, 2010
leecom72
  • 4806 Answers
SOURCE: I have 2 cf-29 panasonic
Hi.
If none of the Panasonic drivers are working then you may need to take the back off the LCD and check either your ribon cable going to the touchscreen,the inverter and/or the touchscreen fuse.
Make sure the battery is taken out and AC power is disconnected before you start.
If you look above your Fkeys you will see a long skinny plastic piece with 4 screws holding it down running the length of the keyboard. Simply remove those 4 screws and gently, but forcefully, pry up the keyboard bezel. It is not hard at all, but is plastic and the length can make it prone to breakage. You will notice with this out, you would then be able to remove the keyboard; it sort of locks the keyboard in place. Once the bevel is removed, you will see 4 more screws, two on the left, and two on the right. These hold the hing cover in place on the LCD side. Remove those 4 screws; then turning your toughbook around to look at the back of the LCD, you will see two more screws on the left, and two more on the right; again hold the back side of the hinge cover on. Remove those 4 screws as well. Once all 8 screws are removed, open your LCD all the way flat, with keyboard facing up, and you will be able to easily lift the hinge covers off. With those off, you will now be able to remove the LCD lid completely.
Check the ribbon cable first just in case it has popped out. If you have to re-seat the ribbon cables that lead to the touchscreen.
Good luck.
Posted on Jun 08, 2011
Touch screen doesnt work on my cf-29
Hi Jade. If you have a windows XP in your machine Try to upgrade to win7 or win 8 since windows xp doesn't come with touch screen drivers.
Jan 23, 2014 | Panasonic CF-29 (CF29NWQGZBM) PC Notebook
Panasonic CF-29 touch screen do not work
Do you have the driver for it? Try install the driver on your PC and see.
Apr 03, 2012 | Panasonic Toughbook 29 Touch (P/N...
Gratis audio driver para panasinic CF-29 TOUGHBOOK
Follow the link enter the details of your laptop download and install your drivers.
Jan 31, 2012 | Panasonic Toughbook CF-29 Notebook
Panasonic cf-29 no sound after format win xp3 instaled
You need sound drivers by the look of it. If panasonic supply drivers for your sound device in XP.
Mar 06, 2011 | Panasonic Toughbook 29 (CF29E3KGRKM)...
I require LAN drivers for my panasonic cf-29
This depends on the specific model number:
CF-29C/D -- Realtek RTL8139DL 10/100
CF-29E/F -- Realtek RTL8139DL 10/100
CF-29H/J -- Realtek RTL8139DL 10/100
CF-29L/M -- Marvel Yukon 88E8053 10/100/1000
CF-29N/P -- Marvel Yukon 88E8053 10/100/1000
Dec 28, 2010 | Panasonic Toughbook CF-29 Notebook
Cf-50 sound problem
You have an incorrect driver - sometimes several different drivers have to be tried to get sound to work. A utility called Driver Magician will detect and tell you what sound device you have, you can use it in free by telling it to register later and it will work to tell you the device name and manufacturer.
Aug 29, 2009 | Panasonic Toughbook CF-51 Notebook
No audio output device installed
Hi
Can you use System Restore to roll back to a restore point when you did not have the problem?
Other wise go to mfr web site and download and re-install drivers
Aug 17, 2008 | Computers & Internet
Computers & Internet Logo
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
